Question about Toshiba e400 Pocket PC
128MB sd card not being recognised
I seem to having a common problem - my 128MB sd card not being recognised. I have seen solutions containing phrases like 'contact service partner' and 'soft start'. What does all this mean?
    Master:
  • 903 Answers
Before you can say that there is some common problem it will be interesting to know if your PDA has the same problem with different SD cards (different producer). As far as I know it can happened that PDA has problem with some cheap SD cards that you can buy at every supermarket. If there is possibility to check it with different cards it will be very useful. If this issue occur with different card in this case it is possible that there is some hardware defect and you should contact a Service Partner! Please check this!
Posted on Sep 11, 2005
Nikon coolpix s630 shows memory contains no images no sd card in it
That is what you get when the camera memory has no images. And the SD card is missing. This does not seem to be a problem. The tool menu will let you format a new SD card.
May 05, 2017 | Nikon Cameras
I CANT SEEM TO PULL PICS OFF SD CARD
A) Please don't shout.
B) What method are you using to transfer the images to your computer ?
Jan 05, 2017 | Cameras
I have a 128MB sd card and it says card is locked?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 20, 2011 | Samsung Digimax 4010 Digital Camera
Hi Sir, I have a problem with my SD Card when im going to read it on my pc. It ask for "format the disk before you use it". When I click cancel, it says"your volume not contain...
Does the SD card have pictures on it? What is the camera model used with this card? Have you tried connecting the camera itself to the PC in order to transfer the card's contents?
Dec 17, 2010 | Computers & Internet
Moto V6 Maxx micro SD card is not recognised
What happens when you put someone else's micro sd card in your phone? Does your phone recognize the other micro sd?
If it doesn't recognize that one, then it is your phone that has the problem and you should contact the manufacturer or the store you purchased it at as it needs service.
Jul 02, 2010 | Motorola Mobility MOTORAZR maxx V6...
My Sharp VE-CG40U Digital camera has a 128MB SD card, what is the maximum size card I can use in this camera. I have tried and 2GB card and that did not work.
The manual doesn't specify a size range for SD cards in your camera, but I've seen 2GB cards offered on line for it. Make sure that the write protect switch on your new card is in the UNLOCKED position and that the card has been formatted for your camera.
Dec 27, 2009 | Sharp VE-CG40U Digital Camera
My pc is not recognising my connected sandisk cruzer control stick?
Solution for ALL PCs with USB 2.0 ports.
1. Move it to the PRIMARY USB port.
2. Check your BIOS configuration to make sure your USB ports are enabled
3. Assign an IRQ to the USB ports ( this is done by Y/N setting in the BIOS )
4. Download and install service pack 2 ( usb 2.0 is enabled by installing service pack 2 )
Thank you for choosing FixYa!
Az. Wizard Division
Sep 23, 2008 | Computers & Internet
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Kingston 256mb SD Card not recognised by PDA
In my opinion it is definitely a hardware problem. If you have the same problem with two or more SD cards it must be hardware. Please contact Service partner in your country and ask them how they can help you.
Sep 11, 2005 | Toshiba e405 Pocket PC
Sep 11, 2005 | Toshiba e400 Pocket PC
Toshiba e400 Pocket PC Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
