Question about Toshiba Computers & Internet
MY COMPUTER IS A SATELLITE A215-S7408. MY PRINT WAS NOT FEEDING THE PAPER- SO I REACHED OVER THE LAPTOP TO TURN OFF THE PRINTER,AND MY BELLY MASHED A LOT OF KEYS ON THE COMPUTER. WHEN SAT DOWN TO RESUME MY PROJECT;ICONS,PAGES EVERYTHNG WAS SIDEWAYS 90 DEGREES
    President:
  • 2,961 Answers
You turned the display be a function button, but without knowing which, use system restore instead, click start>programmes>accesories>system tools>system restore and choose a restore date a few days ago
Posted on Aug 29, 2008
My camera doesn't work on my Toshiba satellite A215-S7413
Please disconnect the cam and remove the cam software from the computer and re install the cam software and connect he device and check it.
Mar 17, 2012 | Lifetime Toshiba Satellite A215S7413...
My toshiba satellite laptop keyboard just quit and won't work, totally frozen and nothing appears as i type. pls help toshiba satellite laptop A215-S5837, windows 7, vista
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
May 12, 2011 | Toshiba Satellite A215-S5837 Notebook
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
Activating crisis mode for toshiba satellite a215-s7422
If you mean safe mode, as soon as you turn on the computer start pressing the F8 button about once a second. That should bring you to the safe mode option.
Jan 04, 2010 | Toshiba Satellite A215-S4747 Notebook
Paper not feeding
try un istalling your printer from your computer,
then install that fixes some problems.
check that the rollers in your printer or not damaged or bent.
Oct 29, 2009 | Canon PIXMA MP160 All-In-One Printer
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
Paper feeding through printer but not printing
hi! if that printer doesn't print at all,since it was configured by your computer,try to check it's properties to test the function of your printer.doing this go to control panel click printer,then right click printer,click properties.on properties click test your printer,if this printer, print but nothing appear on paper,back to your properties and go to maintenance,on maitenance click clean printer,on try deep cleaning if still doesn't print bring your printer to cannon service center to check the printer head. regards and thank's
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Need a manuel for a210/a215 series
Is your laptop connected to a printer? Is the printer working? I will assume your answers are "yes".
Have you downloaded the "manual"?  Or is it simply listed as a document on your computer?  Is it a word or PDF file?  Again I will assume your answer is "yes" and it is either a "word" or PDF file.  If not download the document from the Toshiba support website to an easy to find location on your computer.
Either way, open the document (manual).
Either using the "printer" icon located along the top of the document or click on "file" and you will see "print" in the drop down menu.  Either way "Click" on it and your document will be printed. It may "open" another window verifying which printer to use. Simply make sure the printer you want is high lighted and follow the prompts.  Make sure you have enough paper in the printer if it is a large file.
You can also drag the document to your printer icon and it to will achieve the same results.
It's that simple.  Good luck and happy reading your manual.
Oct 19, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Computers & Internet Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
