Cars & Trucks Logo
Posted on Jul 21, 2011
Tmail.comwhen my 2oo5 sante fe is sitting at idle it doesnt blow cool air as sooon as i put it in drive and go it blows cool air fine
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jul 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
Helped
6200
Points
85
Might have vacume hose off or loose..
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ā€Žluke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
No heat but blows cold air
flush radiator, check coolant level, check heater core, check timing, and if all tests fine get a compression test to rule out head problems.
2005 sante fe a/c blows warm air when idling @ stop light - works ok at higher speeds
You need to recharge your a/c, and check its fuses. It's not blowing cold air at all, even when you are driving, because when you are driving it is blowing in the cooler moving air from outside your vehicle.
Hyunadi Sante Fe 2004 has engine light on and it will drive smooth and idle smooth but then it will jump and then run smooth again,
You need to take your car and have the check engine light read. You can do that a AutoZone for free and they will tell you want is wrong. Can you give more details on the "Jumping" part? Is it when you put it into gear? While its sitting their?
Very little air is blowing through my vents, ac is working fine.
Under the wipers is a plastic shield which keeps dirt out. REmove cover & you will see an air filter usually on the passenger side replace it.
Heat blows cold when car is idling
You have an air pocket in the cooling system. To bled it out you will have to park vehicle on an incline or jack up the front end untill the radiator cap is higher than the heater core. The remove radiator cap and run engine until warm then hold rpm to about 1200 rpm's and top off coolant level until you have no more bubbles.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
