HP phottosmart 4380
Just got one. How do you print envelopes? Can't find any instructions
  • thefirm Dec 06, 2008
    HOW DO YOU PRINT ADDRESS LABELS, ETC. ON HP 4380 PRINTERS? NO INSTRUCTIONS WHATSOEVER WITH PRINTER. THANK YOU
I need help connecting my wireless printed to my lap top.
Jayne
Posted on Mar 30, 2009
  • 73 Answers
If you are printing an envelope for a letter, In Microsoft Word 2003, click on Tools, Letters and Mailings, Envelopes and Mailings, and go from there. If it does not select the address, highlight it first. If you want to print an envelope that is not corresponding to a letter, type it in Microsoft Word and carry on with the same procedure. You will have to test an envelope to see which orientation works so that the front, back and flap are inserted properly. Usually the default is a #10 envelope. There is usually a movable plastic guide to fit an envelope in. Although I have not worked with this particular printer, the procedure is universal.
Posted on Aug 29, 2008
How can i print an envelope
Instructions for printing envelopes can be found on page 64 of the user manual. If you do not have a copy, download one from here:
http://h10032.www1.hp.com/ctg/Manual/bpl10395.pdf
Mar 28, 2015 | HP LaserJet 1200 Printer
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Why would the printer instructions be printing on the envelopes that I feed through??
Have you accidently turned on manual duplex in the print settings on your P.C? this will then print the instructions on how to feed the paper in for duplex (two sided printing) on the envelopes.
Apr 04, 2014 | HP LaserJet 1600 Printer
Printing envelopes it prints crooked
HP OfficeJet Pro K8600 Printer
Printing envelopes
Mar 19, 2014 | HP OfficeJet Pro K8600 Printer
HP Laser Jet P2035 is not printing the "from address" on envelops and even the "to address" is not being printed on the right spot. The envelope size, tray and feed mechanism are...
The easy way to diagnose this is to put a regular piece of paper in and print the envelope on that to see where it is actually printing. This is likely a wrong envelop size selected in your software not a problem with the printer. It is only reproducing what it is told to. Also make sure that the paper options in the print driver reflect the correct settings for size of paper.
Mar 17, 2011 | HP LaserJet 1320 Printer
Printing envelopes
Instructions for how to print will vary based on your software.
The instructions for loading envelopes and the specifications for the types of envelopes you can use are in the User's Guide for the product.
http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
Aug 24, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Envelope printing
With the address highlighted go to Tools, Envelopes, Custom
Enter the custom envelope size
Pick #4 feed method
click OK
Set the feed tray to hold the envelope along the right side.
Insert the envelope with the flap up - push it all the way in.
Print it
Dec 18, 2008 | HP DeskJet 6122 InkJet Printer
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
HP Laserjet Printer 1320
there is no possible to print envelopes in 1320 printers please perchase other small printer
Sep 19, 2007 | HP LaserJet 1320 Printer
171 people viewed this question
jasbo
jasbo
