Hitachi LCD Television
My Hitachi television is stuck in standby mode. It will not come on using the remote control or the manual on off switch on the rear of the set. However there is evidence of the mains supply with the red standby LED illuminated. This television uses the 17PW15-8 power supply
Any points I need to be checking?
  • eugenebarry Sep 01, 2008
    My Hitachi LCD television is stuck in standby mode. It uses the 17PW15-8 power supply. Neither the remote control or the local on / off switch on the rear of the tv will switch it on. I am really looking for answers on the component level. Any ideas on exchanging components to effect repairs.
    Brigadier General:
  • 6,966 Answers
I am assuming that you are familiar with electronic components and circuitry as well as safe practices involve with component level repair. Do you have access to a service manual or at least a schematic diagram? Pls, what have you checked so far?
Hope this be of initial help/idea. Pls post back exact model number, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 01, 2008
  • Louie  Role
    Louie Role Sep 01, 2008
    Standby B+ checks, 3.3V (pin 2 of IC825) & 5.0V (emitter of Q809)?
    trigger pulse (when powering on) at base of Q835?
    Master:
  • 763 Answers
You said that your tv has power right? so in this situation your power supply has not to do with this problem. it should be work by an expert technician with tools in this matter. if your tv is cover on a year warranty, then dont hesistate your self go and repair it.
cheers
CHARCOIS
    Sergeant:
    Champion:
  • 214 Answers
The problem is with power supply unit. you have to get repaired/replaced by an expert
    President:
  • 1,263 Answers
It appears that your power supply module is malfunctioning this seems to be a common problem. you need to replace it have a local tech replace it for you
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
Apex at2002 tv stuck in standby mode
A universal remote control might not work with this set properly. You should try to buy its original one.
Jul 27, 2013 | Apex Digital Televison & Video
My tv is stuck in stand by,and my remote does't switch on the tv
Television is not the main remote control from behind or the side
Feb 15, 2013 | LG MKJ42519615 Remote Control
Tv is stuck in dvd mode
The on l y way I've fixed this problem is by using a universal remote control. Using the input button, you should be able to switch it back to whatever mode you need. Hopefully your television is a major manufacturer.
Jul 03, 2012 | Mintek DTV-373-D 37 in. LCD HDTV
Power is on in standby, but takes several times pushing the power button for the power or tv to actually come on
Very bad for the TV, don't do this!
Got the remote control? Switch on or off (full operation) from Standby with it and just use the main manual switch on the TV for, say, morning ON for the day and evening OFF for the night.
Sep 21, 2011 | Soyo Crystal DYLT032B 32 in. LCD...
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Jul 07, 2010 | Hitachi Televison & Video
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Problems with Jwin JV-DTV30 30 in. HDTV-Ready LCD Television
This sounds like micro glitch try unpluging the tv and all controlable inputs (PC, iLinks, or other such devices) wait 5 min then plug the tv only in and see if you have returned functions. if you should read the manuals of those devices to see if the control functions can be turned off.
Jan 07, 2008 | Jwin JV-DTV30 30 in. HDTV-Ready LCD...
Televison & Video Logo
380 people viewed this question
Top Televison & Video Experts
Electro Med Services...
