Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius WM31 Washing Machine
The machine keeps tripping our electric! I have changed the brushes but this has not helped. I can overcome the problem for short periods by rotating the drum manually (by removing the top and using the belt) The machine then carries on with the wash for various periods of time before tripping the electric again. Could you offer any guide as to the possible cause please?
also does this machine have a filter and if so where is it locared? Could that be the problem?
    Problem Solver:
  • 18 Answers
The tripping can either be down to a short circuit drawing too much current and blowing the fuse , or an earth leakage blowing an RCD. You can eliminate the motor when it happen again , by unplugging it and see if the fuse blows (without turning the drum). Most likely is the heater , but i cannot explain why turning the drum allows it to continue. It is possible a wire is rubbing somewhere on the drum pulley , motor or casing. If the machine will immediately trip again if you don't move the drum , try isolating parts by disconnecting and then retrying.
Posted on Jan 01, 2009
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
Jan 24, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
538 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
