Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have the correct cable
And still not able to comunicate with the router.when i reach step 3 on easy install wizard i have the same problem like before....problem comunicating with the router
    President:
  • 2,961 Answers
You need to reset the router by the liitle pin hole on the back or underside of your router, connect your pc by cable then restart your pc and the router should connect.
Posted on Aug 29, 2008
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
How do i set up the internet security on my belkin wireless router
Place your wireless G router in a wide open and central location. Don't connectthe power plug into the router, yet. Make sure your computer is turned off. 2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernetcable from your PC and insert it into the wireless G router's WAN port. Youshould have an additional Ethernet cable that came with your router. Take thiscable and plug one end into one of the LAN ports on the router. Then connectthe other end to your PC's Ethernet port. 3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll takeapproximately 30 seconds for the modem to boot up. Connect the power plugadapter to the router and the other end into a power strip or outlet. Like themodem, it'll take about 30 seconds for the router to boot. Turn on your PC. 4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LANlight. If you don't see any of them lit, confirm these devices are turned on.Make sure the Ethernet cable connections are installed correctly. 5. Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router.Set up features, such as creating your password and setting up your time zone.Continue to follow the setup wizard so you can configure ?other settings.
Sep 20, 2010 | Belkin (F5D5231-4) Router
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I cant connect to the internet
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
INetwork Password
ask your internet service provider
May 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to change password
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
I have a wireless router i can get it working right?
How to quickly install and use your wireless router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 26, 2010 | Airlink AR430W Wireless Router
I need to enter my code
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 23, 2010 | D-Link 802.11g Wireless Router WBR-1310...
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
