Need play dvd from all regions - Televison & Video
  • 376 Answers
Http://www.videohelp.com/dvdhacks
Search your make and model on the link it has many region hacks. If theres one available for your player it'll be there.
Posted on Aug 30, 2008
RCA blu ray/ dvd video player won't play regular dvd any longer
Laser assembly has lost the ability to focus and play back. Replace unit since repair not cost effective.
Dec 19, 2016 | RCA Televison & Video
Incorrect disc region code
Look at the region code of the DVD that plays on the vehicle DVD if it is the same of the others that do play it's not a region code issue. If the others are a different region to the DVD that plays or the disc says it is region free. Then you might have a problem with the region code settings on the machine. You can look up the model number of that player to see if you can change the region code.
Otherwise check out the player to see if it needs cleaning or is faulty.
Aug 14, 2016 | Televison & Video
Can play a movie using a dvd
You can play a DVD movie disc on your DVD player provided the Region code on the disc is the same as the Region code that is configured on the DVD player.
To play DVDs from any region the player needs to be a region free player or youneed to install a region free program on your notebook/computer.
For details on making your DVD player region free, please click on this linkand follow my instructions :- http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
May 16, 2011 | Compaq (157844-001) Internal DVD Drive
Playing dvd's from another region
Your instruction manual for the Sony system will tell you what region DVDs it will play.  Also the back of the receiver unit will have a number that says what region it will play.  Look on the back of the DVD cases and they will have a region number.  Your player needs to match these numbers in order to play, unless the DVD is region 0, which means it can play on any DVD player. You can buy region free players on e-bay, which means the IT folks have tinkered around inside the DVD players to turn off the region coding.
Oct 25, 2009 | Sony DAV-S400 System
Why does the set not play certain discs (wrong region code)?
You need to check the dvd player manual for region restriction, for region restriction dvd's you cannot play on your dvd player so check the region supported dvd's whcih you can play on your dvd player.
Feb 24, 2009 | Philips Audio Players & Recorders
Sansui DVP1210 dvd player- unclock code
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Jan 23, 2009 | Panasonic SC-HT520 System
I need to unlock my LG DZ9811P DVD so i can play all region dvd's
power on
open disc tray
press 0 0 0 on your remote
select region 0
press pause button
press power button to switch off
leave off 30 seconds
should then play all regions
Jan 19, 2009 | LG DR-4912 DVD Recorder
Cant play region 1 dvd set for region 2
what you need is the region code for your dvd player. so you can play region one and any other region dvds. what is the brand and model of your dvd player? then i can check and see if there is a hacking code for you.
tom
Dec 26, 2008 | Televison & Video
PANASONIC DVD RECORDER DMR-ES35V
DVDs are region coded. This means that they will only play on a DVD player from the region the DVD was produced to be watched in. For example, an Australian DVD is Region 4. It will only play on a Region 4 player. If you try to play it on a player that is set for a different region, it will probably not play. One way around this is to get hold of a multi region player. These are widely available. Alternatively, you should be able to watch the DVD on your computer, although you may need some region free software if your computer's dvd player has been locked. Usually computer DVD players will allow you to play DVDs from any region a few times and then they will lock to a particular Region Code. If you are in North America, you will need a PAL player. The only other thing you may be able to do is to unlock your existing player to convert it to region free. Many DVD players can be unlocked but you would need to find the unlock information for your paticular player. Hope this helps....
Jul 27, 2008 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
