Question about Hotpoint Washing Machines
Need to replace a door seal on an hotpoint WF530 washing machine?
Thank you for your e-mail, for a donation of €50 I will send you the details on how to resolve the problem.
Posted on Aug 30, 2008
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
Hi, I have a Hotpoint Aquarius WF530 washing machine. When I put on a wash program I hear the pump running as per normal part of cycle but nothing else happens. Drum does not fill with water... If I turn...
most probally the control module (bottom of machine) emw electronics are your best bet for a replacement, as otherwise they have to be programmed by hotpoint
Sep 09, 2013 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius WF530 machine
Hi- think I've answered on your other posting ;-0) John C
Oct 15, 2011 | Hotpoint Washing Machines
Where to find filter on WF530 Hotpoint washing machine
The filter is located within the sump hose which is at the bottom middle of the drum secured by a white nylon clip slide it to the side to aid removal...hope this helps.....Good luck.....
Feb 27, 2011 | Hotpoint Washing Machines
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Jan 27, 2010 | Hotpoint Washing Machines
How to replace door seal part number 1603291 on hotpoint washer
Hi -Can I myself replace and repair a seal on a bosch front loader? Thanks for your help and your time!
Thank you,
Nov 17, 2009 | Washing Machines
HI NEED TO REPLACE belt on a hotpoint wf530 is there a simple solution such as adjustor to move motor?
It is quite a tight fit this belt, No adjustment just sheer power/ I use a wooden peg to assist me ...Watch you fingers! Good luck
Sep 29, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma40 door seal
The black grime is mold. Once it is set into the rubber it is nearly impossible to remove. Bleach would have been my suggestion but since you've already tried that, replacing the bellows (door seal) is your next option. In the future, when the machine is not in use try keeping the door slightly open for any standing moisture to evaporate.
Feb 19, 2009 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
