Question about Compaq iPAQ H3630 Pocket PC
Ipaq H3630 how to do a hard reset
I have tried updating my 3630 with your softpaq SP22898 via
serial cable and cradle, backup worked fine but the update will
not work leaving the ipaq dead. Can still access parrot mode
with similar lack of success using softpaq and same error 105.
Have tried upgrading microsoft activesync to version 4.5 but
again, same port error. Update utility is version 1.13. Please
provide some help, I am completely stuck with a useless ipaq
(although the parrot is very pretty!).
    Scholar:
  • 58 Answers
Compaq iPAQ h3630
Resetthe iPAQ H3000 and Clear Memory
Resetting the iPAQ
Ifyour iPAQ H3000 responds slowly, stops responding as expected, or“freezes,” try resetting it. A reset causes the iPAQ H3000 to restartand re-adjust memory allocation. Unsaved data in open windows may belost. Use the stylus to press and hold the Reset button for about twoseconds.
NOTE:Do not turn off your iPAQ as it must remain on in order to reset.
ipaq H3630 how to do a hard reset - compaq_ipaq_h3630_hard_reset_soft_reset.jpg
Clearing memory
Ifyou want to clear all data from your iPAQ H3000 and return it to thefactory settings, you should clear the memory.
Clearingmemory deletes all data and restores the iPAQ H3000 to its defaultsettings. Programs installed at the factory remain, while data you havecreated and programs you have installed are erased.
1.Using the stylus, slide open the On/Off door on the base of the iPAQH3000.
2.Slide the On /Off switch to the Off position using the stylus. Waitabout one minute, then slide the switch to the On position.
3. Close the Battery On/Off doorusing the stylus.
ipaq H3630 how to do a hard reset - compaq_ipaq_h3000_hard_reset_soft_reset_2.jpgads/images/compaq_ipaq_h3000_hard_reset_soft_reset_2.jpg" alt="compaq_ipaq_h3000_hard_reset_soft_reset_2.jpg" class="h_mi" />
NOTE
:Use CF Backup/Restore or ActiveSync to keep a backup of your iPAQ dataso that if you need to clear memory, you can restore the data on youriPAQ.
http://www.hardreset.eu/compaq_ipaq_h3630_hard_reset_soft_reset_en.html
Posted on Dec 30, 2008
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
6.) Place your iPAQ in the USB Cradle.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
Manual
need a manual for compaq ipaq 3630
Aug 08, 2008 | Compaq iPAQ H3630 Pocket PC
I can't install a certain HP update.
1. Download the SoftPaq to a directory on your hard drive.
The file downloaded is a self-extracting executable with
a filename based on the SoftPaq Number above. 2. Establish an Activesync connection between your iPAQ Pocket
PC and host PC.
3. Execute the downloaded file and follow the on-screen instructions
to install the Real Time Update.
4. Follow the instructions to perform a normal reset on the iPAQ Pocket PC.
on step 3 you should see the setup on your pdas screen do you see this?
Waiting for your reply. :)
Mar 06, 2008 | HP iPAQ H1940 Pocket PC
Problem with 3630
unfortunatly this isnt a new issue. http://computing.net/pda/wwwboard/forum/838.html It sounds as though your recharging system has went on the fritz. If this is the case then money signs are going to soon be appearing. replacing the charging system is impracticle and the system blocks startup so this would even cause a new battery to not function properly and also probably what ruined your previous one.
Sep 10, 2007 | Compaq iPAQ H3630 Pocket PC
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
Sep 12, 2005 | Compaq iPAQ H3970 Pocket PC
Connection with my iPAQ 3660
...USB and Serial cradles and cables from... http://www.pdasmart.com/ipaqparts3600.htm http://www.amazon.com/exec/obidos/A...1&link_code=as1 http://www.bizrate.com/buy/noncat_p...--37673232.html There are probably other sites, but these are a few from a quick search... Otherwise, yes via IR if the PC your synching with has IR functionality... BT and WiFi also, but you need to establish a partnership via USB/Serial/IR first... Go to this site and download the Reference Manual, etc... http://h18000.www1.hp.com/support/f...te/48_1334.html You can get the latest version of ActiveSync from... http://www.microsoft.com/windowsmob...tivesync37.mspx __________________ "When all else fails, read the instructions..."
Sep 12, 2005 | Compaq iPAQ H3660
Pocket PC 2002 Self-test on iPAQ 3630
Have you looked into the Start-Settings-Systems and look for a Self-Test icon ? Normally Self-Test program reside there if it's on the Ipaq!
Sep 11, 2005 | Compaq iPAQ H3630 Pocket PC
ROM update
1.Try connecting the unit to the AC Supply. 2.Try Doing the ROM update when the unit is connected to the Cradle.(this is recommended) 3.not Via Bluetooth.
Sep 11, 2005 | HP iPAQ H1940 Pocket PC
Compaq iPAQ H3630 Pocket PC Logo
777 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
