Question about Sega Genesis 2 Console
Adapter Doesn't Work
I have two adapters one works one doesn't which i useless to me as i need a second one for the cd attachment when i plug in another adapter to the genesis the light comes on but i get a blank screen yet when the genesis adapter is in the system works fully
the other adapter is a nintendo one and has the same output as the genesis one why wont it work?
Well buy a new one then it might work.
Posted on Aug 29, 2008
How do i replace radio cassette player with a cd player mazda 6 2002
Don't replace it. Go to Walmart and buy an adapter. It is usally at the check out somewhere and It cost about $5.00. It has a cassette that goes into the cassette player. Then you plug your ipod or whatever into the attached wire. Doesn't look cool but it works and it is inexpensive. The adapters with the cd player attached skip (we had one 20 years ago) so just buy the new kind of adapter for less and play all your up to date gadgets. Put your cd songs on your ipod or iphone. Our son uses one in his truck with his little ipod shuffle. No cd player needed.
Sep 12, 2012 | Mazda Cars & Trucks
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
Cisco 876 doesn't work at all
The power adapter maybe faulty. Test the voltage on the plug that connects to the router with a multimeter, the voltage should be slightly higher than the voltage that is printed on the label on the adapter.
If the voltage is low or zero then the adapter needs to be replaced.
May 19, 2012 | Cisco 876 ADSLoISDN Sec Router
The sd card is too small. It doesn't fit into my computer, it came with a little yellow thing to attach to it but it doesn't work on my computer. Help.
Hello akamacho,
It is possible that you have a "MicroSD card". Most card readers can not read micro sd cards because it is too small, so you will need an "adapter" to be the same size as a normal SD card and then you can use it on card readers. I am just assuming (because I can not see it) that the yellow thing you have is the adapter. Make sure the micro SD card is inserted into the adapter properly and make sure that your adapter is inserted properly into your card reader.
If it is still not working, tell me the brand and model of your computer or you card reader. Also indicate any markings you can read from your sd card and the little yellow thing.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
Oct 07, 2011 | Cameras
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
I have lost my drivers installation cd and got a new computer need the drivers to get this adapter to work.
unfortunately it doesn't look like linksys has made the drivers for windows7. This however is the link for xp drivers, which is under "Downloads"
http://homesupport.cisco.com/en-us/wireless/lbc/WUSB54GSC
Aug 15, 2011 | Linksys WUSB54GSC Compact Wireless-G USB...
Is my AC Adapter for HP Deskjet F380 out of order?
You can contact PRASHANT 9820930880.
I found this on the net while searching for the adapter. Placed the order just now. Not sure how genuine he is
we have hp all in one adapters model f/310/325/335/340/350/370/378/380/385/388/390/394 @400RS. CONTACT : PRASHANT 9820930880
Jan 05, 2010 | HP DeskJet F380 All-In-One Printer
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Sega Genesis 2 Console Logo
76 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
