Did you forgot the procedure to SIMLOCK you Samsung S3653 or did you forgot your phone lock code?? if you want to simlock your mobile then you can do it by unlock codes and for codes try Simpleunlocking and get your mobile unlocked from network and if you want security code try to reset your mobile..
hi you can get the codes to unlock your samsung sgh -e370 from this site theunlockspot here they ask the imei number of the mobile finally they will send you the codes to unlock your mobile along with the instruction about how to enter the codes in your mobile.
How can you forget simlock? Do you want to unlock your sim to use a different network provider. You can unlock it through unlock codes given by some online providers like Classicunlocking.com ..If you forgot your phone lock code you can reset it in any mobile stores..
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved OR: If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
hi codes are the best solution to remove the lock in your mobile .you can purchase the codes from this site theunlockarena here they render the codes for all mobile models along with the instruction about how to use the codes in your mobile.
*#9998*3323# phone will reset. press exit & then press 7. it will
reset again .put in simcard .it will say simlock. put in 00000000 then
it should be unlocked then type in *0141# & the green button and it
unlocked all networks. GOOD LUCK
