Leaking tap? The hose leaks where it is connected to the cold tap when the machine is being used. It doesn't leak when not in use. I thought the hose was faulty so bought a new one but it is still leaking.
    Genius:
  • 1,028 Answers
Leaking on faucet end? probably bad o-ring in fauct head ..leaking on washer end? possible hose is cross threaded on inlet valve take hose off and try to reconnect watching closely as you tighten trying not to cross thread plastic connection can sometimes be recut
Posted on Aug 30, 2008
Leaking washer, increases when using cold, less when using hot. May be at drain?
Stop the washer and clean up the water. Confirm that the water is not leaking when the washer is off. The leak can occur before the electric valves either where the hose connects or from the electric solenoid valves just inside the washer. The situation is more likely true if the hoses are stressed by being bent to one side.
If dry then confirm if it is the hot or cold by running the machine with the cold service valve open and hot closed.
Jan 06, 2016 | Washing Machines
My beco washing machine water hose adapter is
Check for rubber sealing washers at both ends!
Oct 19, 2014 | Washing Machines
My Bosch washing machine is leaking from the bottom of the right hand side of machine when not in use.
g'day, sounds like the leak is coming from the hose - this is because the leak is occurring when its off. Check seals on hose at the back of machine. You can always find old sets of hoses as well (or buy them), so you can try swapping them over. Keep in mind, with washing machine hoses (like gardening hoses), the seal is at the rubber washers not the thread on the tap... so plumbers tap will not stop a leak, it will hinder the seal.
An alternative solution is simply turn tap's off between washes...
Aug 07, 2011 | GE WWSR3090TWW
WATER LEAKING FROM UNDER
Pull the machine away from the wall enough to get to the 3 hoses on the back. Make sure they are all tight. Two will be for hot and cold water and will have a regular threaded connection that can be tightened with a pair of pliers or pipe wrench (tighten both the washer side, and the wall side). The third is the dirty water discharge and will most likely have a worm-gear clamp that can be tightened with a screw driver. After tightening them all, run another load and watch all the connections for any other signs of leaking.
If tightening them doesn't fix the leak then you should replace the gaskets on the two threaded connections. You can get replacements at your local hardware store. Make sure you turn off the water with the valves on the wall before removing the hot/cold water hoses or you will make a big mess.
Jun 19, 2011 | Washing Machines
Broken water line or water heater, from winter freeze. When water is turned on tap water goes under the bunk bed area. Could this be the water heater or a hose in the area. We don't know the layout...
Depends on which tap you're turning ON. If it's cold water tap, it's probably a water line. If it's the hot water tap, it could also be a line. As heaters leak, whether the water tap is ON or NOT. Opening a tap valve doesn't cause the water heater to leak. The main question is, was the water heater's tank drained, before the Winter Freeze, when no one was using it? If it wasn't, there's a good chance the water heater will leak too
Hope this helps you solve the leaking water pipes problem. Please let me know Thanks.
Jun 15, 2011 | Heating & Cooling
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
