Question about Edirol UA-4FX External Sound System
I need help
I dont have sound on my comp,my speakers are working,and they are working on comp when i check them,but otnerwise no..please help me
    Brigadier General:
  • 6,966 Answers
All drivers are hardware specific therefore it would be required to determine the brand and specific model number of the laptop. In some cases, there are multiple versions of the same model so might as well post this also.
Hope this be of initial help/idea. Pls post back brand & mode/version, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
My BOSE (companion 2) speaker is no output sound from my comp.I tested to some other speaker and there is an output sound, power supply is good. What might be the problem?
Hi anthonybongl,
The problem could be that either you have your sound driver uninstalled by accident or your master sound control is set to mute , please check it and then you would be able to recognize the main problem.
Hope this helps ..:)
Aug 01, 2011 | Bose (AA52650) 2 Speakers
No sound
check ur audio driver setting
Jan 21, 2008 | HP Pavilion a1000n (PS567AA) PC Desktop
I have a used dell desk top.I bought Logitech comp. speakers and ive enjoyed listen to some music on utube,until the other night. The sound went totally out! Thinking it was the speakers, I unplugged...
Hi
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
  • Ensure Volume is not in MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
  • To confirm follow next step or ROLL BACK THE DRIVER
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx For another check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). So please go there website>supports>download For download Suppose, you need driver for, ASUSK8V-VM
http://support.asus.com/download/download.aspx?SLanguage=en-us Product =Mother Board So Series = (Socket NO.eg. 754etc.) So Model = (Model no will beK8v-vm) And please select the O.S (XP/ VISTA / WINDOWS 7) version of the drivers that matches yourP.C and search. Now you can download easilyone after one. Hope it will help you.
Feb 23, 2011 | Dell Dimension 3000 PC Desktop
I plugged my speakers in to the sound card and it
Hello!
You must try 2 options.
Try uninstall sound card drivers, reset comp., and again install sound driver.
In second case you must try new system, with full format hard drive, because you can have trouble with virus, and that is only safe way.
You can also try another sound card, but I think that is you sound card OK.
Nov 02, 2009 | HP (400745-001) Sound Card
My New sound card did work, but i had to Format my comp.
CAREFULLY remove your sound card and then try to boot up.
if it does not boot up then your computer has a problem and you need to consult your MFG.
if it does boot up then check the specks on the sound card and check if it is compatable.
if it is compatable, make shure that the contacts are clean (use a compressed air cleaner), and that the sound card is not damaged, then reconect (with the computer off).
______________________________________________________
In the way of only one speaker working, you probably have a loose connection; bad cable; or a bad speaker.
Aug 18, 2009 | Pine Technology XFX Mach4 KT400ALH...
Speakers on comp. arent woking
This a try it ok .
Go to control panel
and then to your audio
and check and see if it is mute or checked on
I hope this is the only problem
Feb 12, 2009 | Dell A215 Computer Speakers
One speaker not working
Left/Right balance can be adjusted in the "Sounds and Audio devices" in Control Panel. If the adjustment is not the issue then the soundcard is at fault.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Nov 14, 2008 | Harman Kardon SoundSticks Computer...
My computer is saying no audio device
Ok lets do like this
If you your mother board CD ,?  get play that and you will find an option for sound and audio devices , please reinstall that.
I hope it will work  .Please do reply..
Dec 21, 2007 | Sakar Adrenaline Computer Speakers
No sound
Look in your tv settings menu and see if the speakers are turned off there is an on/off setting in the menu..
Dec 15, 2007 | Protron PLTV-32 Television
Only two of the speakers are working
have you used the mic input connection as this is used to split the channels
May 21, 2007 | Logitech X-530 Computer Speakers
Edirol UA-4FX External Sound System Logo
46 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
