Crown com-tech 2 channel 400
Hi it's an older amp, By Crown,Ive had it a long time im a drumer and I use it as a practice amp in my studio here at home so it never gets moved.Now when I turn it on the amp starts it startup and the number 1 channel the yellow light stays on and the 2 green lights start turning on and off and it makes a crashing noise from just that number 1 channel or the right side,even with just the speskers pluged in,can you tell me whats wrong with it ,Thanks Dave,P
  • ccstables55 Aug 30, 2008
    Hi Dan thanks for putting in your time on this,I thought that was what it was but hell im a drumer its the best practice amp I ever had I live on a 40 acre place out in the country and you can have a dam good time and no onego's to jailLoLI took the top off just to look nthing elles,I cnt fix it right now dont have the cash,maybe 2 to 3 weeks I hope,You al take care and again thanks for your time,I'll spred the word abou you guys ok .
  • 4,234 Answers
One channel has failed and is in need of repair. There are some transistors inside that are "noisy" and sending signals down the line. This is a bit tricky to find, but a service shop that does audio repairs should be able to fix this. Figure about $15-$45 for parts depending upon what circuits are effected.
Dan
Posted on Aug 29, 2008
  • ABRsvcs Aug 30, 2008
    Thanks for the feedback. Feel free to ask more when the time comes. If you don't mind, could you please rate this as that is the only feedback we get here at Fixya.
    Always glad to help,
    Dan
Crown macro tech 3600VZ AMPLIFIER
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Sep 14, 2008 | Crown MA-5002VZ 2-Channel Amplifier
Clip led
That particular channel is blown. These are not the easiest units to repair. Given that this is a commercial amp, I would recommend that this unit be brought to an authorized Crown service center for repair. Expect parts cost in the $50 range plus the labor charge.
Dan
Apr 07, 2008 | Crown CE1000 2-Channel Amplifier
Crown XLS 602 Amplifier - Channels sound different
you are riight there exist several amps like that they having different frequency on each side i supose its not properly made like that or better they wanted a pasty sound on one side and a thin on the other many times it happened to me - in older days specially lots of european amps the solution is a equalizer on the front and equilze it smoth how u want it
Apr 15, 2012 | Crown XLS 602 2-Channel Amplifier
How much watts is the crown ce 2000
Depending on the configuration of speakers you have it will deliver different amounts of power up to 1950 watts when used to power a single 4 ohm speaker. Typical usage would be powering a pair of 8 ohm speakers, in which case it will deliver 400 watts per channel/ speaker.
Sep 16, 2011 | Crown CE2000 2-Channel Amplifier
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Fault lights
I'm not sure what you mean when you say the channel 2 does not work in bridge mode. Bridge mode effectively turns the amp into a mono amp, thus there is no channel 1 or 2. The fans will only turn on when the heat is high enough, so that is not a problem. Please describe what you perceive as the problem with these and I'll try to help.
Thanks,
Dan
Nov 04, 2008 | Crown CE1000 2-Channel Amplifier
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
463 people viewed this question
 Grubhead
Grubhead
