My hitachi lcd will not come out of standby mode it uses the 17pw15-8 power supply. have you got any ideas
  • 1 more comment
  • eugenebarry Aug 29, 2008
    my hitachi lcd will not come out of standby mode it uses the 17pw15-8 power supply. have you got any ideas
  • eugenebarry Sep 01, 2008
    You do not appear to have answered my question, this power supply is built from many components some of which fail from time to time, they are all soldered to the board which means they can be replaced. ageing components cause failures. The faults can usually traced to resistors, capacitors power transistors transformers etc. through the use of schematic diagrams.
    Change the power supply or get a technician is not the expected answer from a television technician
  • pini1964 Oct 26, 2008
    problem with apex lcd that uses power supply 17pw15-6 no standby led wont start up
Stuck in standby can be caused by c877 and c878 both box type caps 15n 400v. But the fault which is causing most of this is Q837 suface mounted transistor type bsh103 which is connected to pin 8 of sg3525a control ic807.
Posted on Sep 22, 2008
  • obbig Sep 24, 2008
    uses common psu type 17pw15-8 vestel . disconnecting collector of Q837 will allow set to start - recommend replacing . q837 is in the soft start of ic825.
Try changing the two 15n caps c877, c878 at the top left of the psu.
Or the 1000uf c806 at the center of the psu
Posted on Jan 24, 2009
  • 2,920 Answers
Have the resistors checked by a tech
Posted on Aug 29, 2008
2 Suggested Answers
  • 1263 Answers
SOURCE: Hitachi LCD Television
it appears that your power supply module is malfunctioning this seems to be a common problem. you need to replace it have a local tech replace it for you
Posted on Sep 01, 2008
Why does my hitachi lcd television go to standby after watching it a while?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 12, 2014 | Hitachi 50V500 50 in. HD-Ready LCD...
Sep 01, 2008 | Televison & Video
I cant get our hitachi 42hds69 out of standby mode. I have unpligged the tv as well as turned off and on the main power
there are several things that could keep a set from coming out of standby mode. It could be a defective power supply or a defective main board. You will need to have the set diagnosed to see why and which board is causing the problem.
Jun 06, 2012 | Hitachi Televison & Video
Standby mode
Standby power supply runs 7/24 and this should indicate it is not allowing main power supply and hence the set to turn on= short someplace is most likely issue.
Does red light blink and in a sequence of blinks?
Apr 23, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hitachi LCD L42S504 not working
If only 5 volts likely the standby supply is working:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Apr 02, 2012 | Hitachi Televison & Video
Hi My Hitachi is in standby mode (not turning on - only have red standby light on). I have visually checked capacitors on 3 main boards and none appear to have expanded. Any ideas please?
First thing to do is measure the output voltages of the power board. You're looking for the one that provides standby power, usually +5V or +3.4 V and in some rare cases other voltages.
Don't know what it is for your TV, but it will sure be available on the power board if you see the red LED there.
Next you look to see if upon pressing power the main board signals to the power board to turn itself fully on, i.e. start generating the rest of the supply voltages.
There's a pin on the power board's connectors that is labelled "PS_ON" or just "ON" or something similar.
It should raise to +3V or so when you press the ON button.
For an example of a simple power board see this:
If you do not receive that signal then the problem is in the main board.
if you receive that signal, but the power board does not generate the additional voltages that it outputs to the other boards then the problem is in there.
And if it wakes up and provides those voltages but the TV is still dead then the problem is in the main board, which usually needs to be replaced.
Hope this helps. If it does do not forget to rate it :-)
if you need more help - supposedly paid though - feel free to contact us.
Oct 18, 2010 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Jul 07, 2010 | Hitachi Televison & Video
Hitachi 50v 500a
This fan is to cool down power supply temperature and even in standby mode power supply works.
Nov 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Re: standby mode???
No really the standby mode dosent mean the sets fried or unrepairable. It just means that the sets in a shutdown mode till a power supply problem is corrected. They have shut down protection when the power supply dosent regulate the b+ and if it didnt shut down it would give off tons of X type radiation. thats just a safty on the set. seek a pro to assist you in repairing the set. Good Luck
May 16, 2006 | Hitachi 50EX01B 50" Rear Projection...
Televison & Video Logo
2,206 people viewed this question
Top Televison & Video Experts
