There is no sound on channels 47 & 55 and other chanels the volum drops off. Would a tv repair person be able to bring a Mothre board to me so that there would not be any down time?
  • 13,433 Answers
Hey,
reset your tv settings, some channels may be set to mute?
you will have to contact a repair person direcly, as fixya is a technical support service, You can try the find a repair service on the right side ->
if you don't see it you may need to scroll down the page.
Thanks,
Ekse
Posted on Aug 29, 2008
  • 435 Answers
Please let me know the model details.
  • Narmada Anand
    Narmada Anand Aug 29, 2008
    This is most likley a problem in the audio amp circuit in the tv. the problem is a repair cost will run 300-400. this is more than you should put into the tv. why dont you try running the aux audio out (rca jacks) on the back of the tv to a stereo and use the stereo for your sound?
    let me know if you uneed more info here.
I just bought this 25in zinith tv!!it has a remote but i cant figure out how to get v1 and v2 chanells so i can watch netflix on it? can anyone help me?
19 worked for my Samsung Blu-Ray player remote
Now I can ctrl mute, volume, channel up-down and power on/off on VIZIO (M470NV) 47" Razor HDTV, thanks
Sep 04, 2013 | Zenith ZEN700 Remote Control
My wife says that the muteki 7.2 chanel does not need to be going all the time um something todo with the over useage of power so how do i just run the tv without the muteki going as it wont go meani
You can turn off the 7.2 channel surround sound system if you only want to listen to audio on the TV channels, you may need to increase the volume levels on the TV.
Use the 7.2 channel surround sound when you want surround sound when playing DVD movies.
Jan 10, 2013 | Sony MUTEKI HTDDW1600 Theater System
Sony FD Trinitron WEGA started changing channels on its own for 2 days, then the remote stopped working. When the volume button on the tv is used, the first time pressed it will bring up the favorite...
it is a rare problem ..... only after opening & observing all circuit boards one can tell whether it can be repaired or not .... if on any circuit board at any IC or transistor if board has become brownish or blackish colour then either that component is gone or there connection is loose ........ on observing carefully if we find cracks at soldering joints of that particular component then your tv problem can be solved by just resoldering those joints carefully ...... if no such cracks are found means then those particular components where board has become brown or black has to be checked ...... so in your case only after opening backside cover & observing circuit board one can say problem is minor or major - can be repaired or not .............since sony is very good brand before going for new tv just ask some technical person ( may be any of your friend or a local tv service engineer ) to observe all circuit boards of your tv & give his opinion .........
Sep 30, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
The center chanel port does not produce sound and sparks when i plug the wires into the jack. all other chanels work except the center.
It seems that the center channel has DC voltage at the output terminals, center channel amplifier is blown and you need to bring the receiver into a repair shop. You can use a voltmeter to check DC at speaker terminals, all channels should have 0 volts when no input signal applied (or volume control set to minimum).
Do not connect your speaker you can damage it.
Jan 09, 2011 | Audio Players & Recorders
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
Jul 01, 2008 | JVC KS-AX4750 Car Audio Amplifier
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
