Question about Toshiba Satellite A10 Notebook
WI-FI Hi, just got this laptop secondhand works ok but how do I get Wi- Fi to work, tried switch on front but no light comes on. Also have tried a Wi-Fi in the usb socket but no results, works ok on ethernet Thanks Brian
I guess that not every computer has the WiFi, under the WiFi-cover of my computer it´s empty - but I have the switch on the front...
Posted on Jun 04, 2009
If you have the same problems with usb then your problem lies outside the laptop. if your led does not light it is possible your laptop wasnt wired for wifi or your led is not working. Where you place the wifi card is there 2 wires 1 black and 1 white
Posted on Sep 12, 2008
I have a Galaxy Tab s 8.4 and the wi fi has stopped working and won't switch on. other items connected to the wi fi are working ok.
Hi
Look around the sides or front and back there is a button on your galaxy tab somewhere around the edge;s there is a button to be turned on try it
thanx tom
Nov 21, 2016 | Samsung Galaxy Tab Tablet PC
Turn on my wireless wi fi on my lap top saying my lan in os is off
On many laptops, there is an external switch to turn the wi-fi on/off. This is normally found on the front or sides of the laptop case. It can be easy to turn off the wi-fi accidentally if you grab your laptop a certain way that causes you to press the switch.
On some laptops, you will find the wi-fi on/off switch by raising the laptop screen to expose the keyboard. The switch may often be found by looking at the area above the keyboard. In almost every case, the wi-fi on/off switch will be lit if the wi-fi is on, and unlit if the wi-fi is turned off.
Feb 28, 2015 | Medion Computers & Internet
Hi, i have a acrr aspire one, it was not mine and can't get it to get wi-fi or internet, am not very good at this neither, i realy need help.
First, loof for a special icon along the top row of your keyboard. One of those keys turns wi-fi on and off. You may need to hold down the "FN" key while pressing the wi-fi key. Make sure that you have selected the wi-fi "on" setting. Next, you can try going somewhere that has free wi-fi such as a Starbucks coffee bar or a restaurant. Open your internet browser (Internet Explorer has a large blue icon of the letter "e"). See if you get on the internet. If so, your wireless adapter is working OK. Now, most homes have wi-fi that is password protected. Click on the little bar graph icon in lower right corner of your screen and a list of available wi-fi networks should appear. Choose your home wi-fi and click on Connect. This will open a screen where you must enter the passwordor passphrase to gain access to the wi-fi. Good luck.
Nov 13, 2014 | Computers & Internet
My wi.fi not working
Did you turn the wireless switch on which is on the side or at the front of the laptop?
May 07, 2012 | Dell Inspiron Mini 10 Notebook
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
Cant turn on wireless capability
Press the Fn Key and then while holding it down press F1 key. There will be a pop up box come on screen, click wifi enable and ok.
Its that easy.
Sep 02, 2009 | Computers & Internet
I have an HP Pavillion DV4000. My built in wireless is not working. The light at the top of the keyboard does not come on. How do I get it to work?
you can see the wi-fi switch...you turn on and it will work if you install already the wireless driver...its only the problem with the switch combination between wireless..there some option also for enabling the wi-fi...you can press FN key + wi-fi botton.
Jan 28, 2009 | HP 14.1 Refurbished Thinkpad, 1.13GHz...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Toshiba Satellite A10 Notebook Logo
229 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
