Question about Toshiba e400 Pocket PC
E400 screen
Hi, i've a got e400 which when turned on produces mainy different colour lines going verticall y on the screen......???? How can i fix this?
    Master:
  • 903 Answers
If this happen every time you start PDA I assume that the display is defective. I don’t believe that you will be able to fix this on your own. In my opinion you should contact service partner in your country.
Posted on Sep 11, 2005
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
Aug 30, 2012 | Hitachi 42HDT79 42 in. Plasma Television
My computer screen has lines going verticale through the screen and we bought a new screen but that was not it how do i get the lines to go away (color of lines is yellow with blue
Please check your video card if there is no problem with it. Try to use a different video card that is compatible with your pc and check if the lines still appear.
Sep 13, 2010 | Computers & Internet
Toshiba XF355 has a column of coloured vertical l...
A very common problem with toshy lcds is the tcon connectors need cleaning. Failing this a replacement tcon board will put matters right.
May 20, 2010 | Televison & Video
Hello, on my screen i've got 2 little verticale lines with the collors yellow and pink/red. i put a extern screen on my laptop and i don't have hem anymore. so can you help me
Hi there! Try these things,
Since you have already tried to put an external monitor and you didn't see the vertical lines, there's a high
chance that your lcd is having a problem,
because when you plugged in the external monitor that is the test to check the video card,
try to run the lcd bist on the lcd,.. while the computer is off press and hold D + power button at same time,
you should see colors flashing then after that in that test you should see the vertical lines if not then go to bios setup that will be f2 when you turn on the computer.
hope this helps!
Feb 28, 2010 | Dell Latitude D505 Notebook
Monitor changed to yellow colour.... what is the problem...?
Monitors mix the 3 "primary" colours, in various proportions, to produce all other colours.
Mix equal parts of all 3 colours, and you get WHITE.
Mix equal parts of only 2 colours, and you get YELLOW.
So, either:
1. your computer's video-card is not sending the 3rd colour;
2. your video-cable between the computer and the monitor is broken, and is not transmitting the 3rd colour;
3. your video-cable is not TIGHTLY connected at each end;
4. the electronics inside the monitor that SHOULD be producing the 3rd colour have failed.
Try connecting the monitor to a different computer, with the same video-cable. If it works correctly, your video-card is the problem.
Try connecting the monitor with a different video-cable, to see if replacing the cable fixes the problem.
Try connecting the monitor to a different computer, with a different video-cable. If it still is incorrect, then the monitor needs repair/replacement.
Jan 14, 2010 | Computers & Internet
Vertical lines on screen in different colours
Hi dzokosim,
Please go in bios mode and check whether the lines are coming there or not.
If lines appear after some time then keep system in BIOS for that much of time and check.
IF coming then this is the issue with the screen otherwise with the system problem and graphics driver is to be reinstalled.
Jan 30, 2009 | Computers & Internet
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Blue reflection on my screen
Hi.
Check & adjust the convergence.
http://dc07.atspace.com/
Chris..
Dec 15, 2007 | Televison & Video
Toshiba e400, Windows Mobile Second Edition
We´ve successfully reverted back to the original windows mobile 2003. Was no problem. This English Version is Worldwide... Also for your Canada PDA
Sep 11, 2005 | Toshiba e400 Pocket PC
Toshiba e400 Pocket PC Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
