I have acer aspire laptop purchased from dabs feb 2007 hard drive crashed 2 weeks out of warranty, i have put in new hard drive, how much would it cost to puirchase the discs for operating system serial number 64901850625 aspire 5051 xp pro was the operating system gaynor stevens
  • gaynor12 Aug 29, 2008
    thank for your help whats a OEM? and if I purchased the xp you mentioned would that reinstate the operating system? sorry to be so dull not really into technical
    gaynor
    Brigadier General:
  • 6,966 Answers
If your Aspire laptop has a Microsoft sticker at the bottom with the Product Key, it is not necessary for you to re-purchase CD installer of the Operating System. You could try borrowing from friends their XP Pro CD installers or even an OEM and simply use that. When asked for the CD key, use what is printed in the aforementioned sticker.
As long as the motherboard/entire machine is not replaced, then this would be an acceptable alternative. Should you still wish to purchase an Windows XP Pro SP2 installer CD, it would roughly cost USD 60.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 29, 2008
  • Louie  Role
    Louie Role Aug 29, 2008
    Hi again,
    OEM (Original Equipment Manufacturer) - CDs normally given out as recovery/re-installer of the PC manufacturer and not necessarily by Microsoft but contains Microsoft product (XP).
    The
    Windows XP Pro SP2 installer CD would reinstall an updated/better version of the original Windows XP Pro SP1. Incidentally, there is now an SP3, however, you are still good with SP2.
    Next to consider would be the motherboard drivers but will get to that once the new HDD has been re-installed with XP. I am assuming that you are using a different computer accessing this site.
  • Louie  Role
    Should it be agreeable, Pls use the "Ask Me" button to post succeeding queries.
    Glad to be of initial assistance and appreciate the rating.
ACER ASPIRE ONE 722 PE1VE6 // STILL NEW BUT IT WILL CRASH DUMP. WHAT'S WRONG WITH IT? IS IT OK TO INSTALL SKYPE ON IT?
Hello.
If your Aspire is new and getting these errors, there may be a hardware error. If so, return to the manufacturer if still under warranty.
Check hardware by pressing F8, F10, or F12 repeatedly and loading diagnostics. Run the diagnostics and see if the hard drive has problems.
In either case, return the Aspire One.
Hope this helps.
Aug 28, 2011 | Acer Aspire One AO722BZ454 116Inch HD...
My laptop is saying Check Cable Connection! PXE-MOF: exiting Intel PXE ROM No Bootable device -- insert boot disk and press any kEY BUT i dont have a windows disc because it didnt come with my new...
That message means your hard drive has crashed! You'll need to remove the drive and hook it up to an enclosure to see if you can still access the files. Swap the old drive out with a new one, reinstall operating system and you're back in business.
Mar 18, 2011 | Acer Aspire One D255-2670
Acer Aspire 150 - bought new 18 months ago and have been told that the motherboard has gone. Is this reasonable and has anyone else had a similar probelm and if so what did you do about it?
Is this reasonable? - no, but possible, yes. I have seen plenty of electronics go bad just a week or two past the warranty, including computers. Unfortunately, about all you can do about it is 1) get a new motherboard installed, or 2) get a new computer and this time buy the extended warranty. By the way, whoever installs your motherboard should be able to easily get your documents/files from the hard drive. You will need to reinstall Windows, and a new motherboard/processor will require a new installation. Just putting the hard drive back in will produce the "blue screen of death" just so you know ahead of time.
Oct 09, 2010 | Acer Aspire One A150-1006 Notebook
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
I have a dell studio 1737 laptop i purchased in Feb of this year. my computer works for about 10-15 minutes then crashes completely. i went into safe mode and found that the consumer IR devices will not...
0F00:065D is a hard drive read test failure. the hard drive is failing. If purchased in Feb, the system should be under warranty call Dell Tech Support to get a replacement hard drive. (800-624-9896 in USA)
If out of warranty you can get a 2.5 in SATA HDD at Newegg.com for about $60
Dec 05, 2009 | Dell Studio 1737 Laptop
Acer Aspire 5100 crashing
search the help fill on your pc for the fixed drive problem or try google
Nov 17, 2008 | Acer Aspire 5050 5430 Laptop
I had a computer crash I bought a new computer and put the hard drive from the old one as second
yes it is working but I cannot see any of the admin files... I can see the user files.
Any suggestions?
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
