Question about Toshiba e405 Pocket PC
SD Card error 31
Whenever I try to update the SD card (which reads fine) I get Windows Error 31 and the update does not work. This is the same for all SD cards I've tried. The OS is Pocket PC 2003 v4.20.1081 (Build 13100). Any ideas how I can get the pda to write to SD cards?
    Master:
  • 903 Answers
Hi Simon, what do you mean with 'update the SD-card'? I hope that SD card is not “locked”.
Posted on Sep 11, 2005
SOURCE:
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Card Error Message
the error message is because the 2gb sd card is not supported (is too big for the camera)
try 1gb sd card and it should be fine
Jul 17, 2008 | Samsung Digimax 4010 Digital Camera
My e310 cannot format my sd card
I had the same "error 31" problem when trying to format a 2 GB SD card. I then tried a 1 GB SD card and it worked fine. I wonder if the device only supports up to 1 GB cards?? I checked the user guide and it does not say one way or the other.
Mar 25, 2007 | Toshiba e310 Pocket PC
SD Card error 31
Sep 11, 2005 | Toshiba e400 Pocket PC
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Toshiba e405 Pocket PC Logo
209 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
