Question about Compaq Computers & Internet
COMPAQ MODEL5050 - ERROR MESSAGE:PXE-E00- NOT ENOUGH BASE MEMORY. (FRESH INSTALLATION OF XP. WAS GETTING SAME MESSAGE BEFORE INSTALLATION)
    Brigadier General:
  • 6,966 Answers
The error message " PXE-E00: This system does not have enough free conventional memory. The Boot Agent cannot continue." indicates a probable BIOS error in memory management. Corrective solution would involve flashing and updating the BIOS. For a Compaq Presario 5050 Desktop PC, information and relative download for the BIOS update would be here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 29, 2008
  • Louie  Role
    Louie Role Aug 29, 2008
    Hi again,
    I was under the impression that your Compaq Presario 5050 Desktop PC was operational prior to the error message using Windows XP. Anent to this, it was then my presumption that you have pre-installed sufficient memory and/or the system's performance was acceptable.
    Should the above be not the case, pls consider Hanto's solution as a primary action.
    Sergeant:
  • 226 Answers
Your computer was designed for Windows 98 not XP, XP needs at least 256 MBs of memory to run even near efficiency and your model of computer originally came with 96 MBs as witnessed by the company website here
While it is possible to get XP to run on your machine you are trading off a lot of wait time watching it slowly run with the limited amount of memory as originally placed in the computer by manufacturer. The RAM on the computer can be upgraded to 256 MBs according to company website which should cure your problem at least in the case of most of applications, but NOT all.
Present day ( modern RAM ) cannot be used on your system, and finding it locally may be difficult unless you have some variety of computer stores in your locale. You will need SDram. Recommend you make a print out of the page I referred you to and starting making phone calls or shopping on the web.
It doesn't hurt to pay a little bit more for this SDram as you want to be sure you have a good return policy just in case. Most technicians will not charge you extra to install the memory themselves if you buy at their local store.
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
Hp compaq 6720s says pxe - e61
PXE is the boot option from a bootable network card, so basically the BIOS isn't seeing any of your bootable drives and going trying to PXE-boot off your network. Check the boot options in your BIOS and make sure your drives are detected by the BIOS. If they are not listed, then the drive has likely gone bad.
May 05, 2010 | HP Compaq 6720s PC Notebook
I have a message that says , error message: PXE Media test failure chek cable
PXE or Pixie errors occur when the system tried to boot to the network connection and failed. This error usually occurs when the hard drive fails. If your system does boot to windows and you are just getting the error, then you can change the network card setting in BIOS to turn PXE boot off.
If the error occurs and the system doesn't boot to the hard drive, then the hard drive has most likely failed.
Sep 30, 2009 | Compaq Armada E500 Notebook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
Compaq 2500
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
May 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
My compaq n410c won`t start ,it get viruses.. need help
A friend clean the hard drive and load a fresh windows xp...
Thanks
Jan 22, 2009 | HP Compaq Evo Notebook N410c
Can i install windows xp on compaq presario 7360 . because it says memory size error
memory size error means that the computer doesent have enough physical memory to run windows xp,
Jan 04, 2009 | Compaq Presario 7360 (163874-003) PC...
Won't boot
The error means that the computer is not seeing the hard drive.Hit F10 to get into BIOS and check that your hard drive is showing . If it is hit ESC and tell it to save settings. Then restart the PC.
If your hard drive does not show in BIOS, there is something wrong with it. It may be co-incidental that canceling the scan caused your hard drive to fail.
You can try to do an XP repair. Boot your XP cd:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Compaq Presario R3000 Notebook
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
330 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
