Question about HP iPAQ H5455 Pocket PC
Power supply My ipaq 5455 seems to work fine when plugged into the wall charger but only goes through a few seconds of start up with a fully charged battery. Any ideas or suggestions as to the problem and solution?
    Master:
  • 450 Answers
You may need to upgrade the ROM.
Posted on Sep 11, 2005
SOURCE:
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Just got the syma s032 gyro charged it to full and it wont fly for more than 20 seconds
So your only getting 20 seconds of flight time when your charging for a full cycle?
I purchased the Syma Chanook and it had the same problem , If you keep running into this problem using the remote control charger than I suggest to aquire a new charger . One that is a plug in the wall . I really dont like to rely on the usb chargers they just dont work as well. If not you still have a 30 day moneyback warranty and I would make them replace the battery or better yet the whole unit if the second charger doesn't work!
Dec 24, 2010 | SYMA Toys industrial Syma S032 Ready to...
BB Curve 8900 cant turn on!!! Pls help
Try to Re-Charge your phone with electrical charger for 6 hr,
then try it
Jul 14, 2010 | RIM Computers & Internet
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Can't seem to get my dvd player to charge.
I have this model dvd player and it has worked very well for over a year. Lately it has not had a picture but has had sound when fully charged. When the green light is on, it is charging. When the light goes off, it is fully charged (or should be). I plugged the wall charger directly into the dvd player and it works fine with pic and sound. I think maybe the rechargable battery is on it last legs. I am looking for a longer cig lighter charger cord to reach the headrest so kids can watch from backseat. I will be able to keep it plugged in to charger at all times. Hope this helps!
Apr 06, 2009 | Spectroniq PDV-70X
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
Does not turn on
There are some known issues with the included charging equipment. Personally, I ordered a relatively inexpensive charger from Amazon.com that works wonderfully. All you really need is a device that turns a standard wall plug into a USB charger. You can then plug your base that the ipaq stands on into that and it should begin charging. The old battery is probably dead (mine was), but try to charge it anyway.
Note: The actual cord that came with my charger DID NOT WORK. It is sitting in a box somewhere, and if its the same thing I had (it probably is), then you just need the wall-to-USB converter.
This is what I bought:
http://www.amazon.com/iPAQ-rx3715-Sync-Charge-Cable/dp/B000DT8F0A/ref=sr_1_4?ie=UTF8&s=electronics&qid=1204335733&sr=8-4
It is only $10. Again, the cord didnt work for me. Maybe it will for you, but if you manage to find just that converter for less money, more power to you!
Feb 14, 2008 | HP iPAQ RX3715 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
HP iPAQ H5455 Pocket PC Logo
67 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
