Spark Plug Change
I was change my plugs and wires and I was going one by one so I wouldn't get them misplaced a neighbor came out and missed placed them on the distributor cap. So if you could help me out with a diaframe on correct placement and a easier way to get the them since the distributor is back of motor and in the middle.. Just in a hard to reach area. please help i have to get this fixed asap..
  • 45 Answers
Check your manual for the firing order. If you can find that, then you only need to find one plug and you can work the rest out.
Take out a spark plug and stick your thumb over the hole. If you've got to do them all, take them all out.
Manually turn the engine over (or have a friend do it) untill you can feel the compression stroke.
At the top of the compression stroke, look where the rotor arm on the distributer is pointing: this is the lead for that cylender.
Posted on Sep 29, 2008
2004 linconl aviador Have code p0301, p316 I
If you are saying everything is ok when the engine first starts but number one starts to miss when at operating temp. Sounds like the number one coil has developed a internal crack that opens up when hot or at operating temp..causing a miss.change it.but before changing the coil check the spark plug wire it may be breaking down when hot..good luck
Oct 21, 2014 | 2004 Lincoln Aviator
1993 buick riviera miss in engine loses power on inclines has ruff idle. Replaced 2 coil packs, fuel filter, and the PCM. Still having the problem
Change the spark plugs end wires. One bad plug or a wire can cause a miss like you wouldn,t belive. Evan on a vehicle with low miles on it.
Oct 26, 2012 | 1993 Buick Riviera
I want to change my own spark plug's
Instructions
    • Locate the spark plug cables along the top or the sides of the engine, depending on CR-V model. Once the engine cools, use the trim panel tool to twist the spark plug wire at the wire's boot, which is the larger rubber portion located on top of the spark plug.
    • 2Pull back on the spark plug wire to remove it from the spark plug.
    • Place the socket on top of the spark plug and turn it counter-clockwise to unscrew and remove the spark plug from the well.
    • 4Rub anti-seize lubricant onto the new spark plug threads and on the tip of the spark plug.
    • 5Insert the new spark plug into the well. Manually turn the plug clockwise to thread the spark plug into place.
    • 6Test the tension on the plug with the tension testing tool. Adjust the tension as needed. Honda CR-V spark plugs generally need a tension between 10 and 15 foot pounds. The spark plug's packaging indicates its suggested tension.
    • 7Replace the spark plug wire, turn it from side to side and lock it into place. Continue the process with the rest of the spark plugs one at a time until all of the spark plugs are replaced.
Jun 24, 2012 | 1999 Honda CR-V
When i hit the gas the car acts like its going to stall 95 cadillac sls do you think its a bad spark plug
one bad spark plug will give you a miss. 8 bad spark plugs could cause your symptoms, but I would be checking fuel pressure, and throttle position sensor signals. If all your sparkplugs were bad it would run lousy all the time, not just when you hit the gas. Also, if you are going to change the plugs, change the plug wires as well.
Sep 02, 2011 | Cadillac Seville Cars & Trucks
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
Missing under load, When accerating or climbing a hill my LOW milage 4runner is starting to miss. what could it be? Spark plugs or ?
Start with the simple things first. When was the last time you had a complete tune up? "Missing" could indicate bad spark plugs, bad spark plug wires, or bad cylinders. Change the plugs first, then go from there.
Nov 06, 2010 | 1998 Toyota 4Runner
How to change the sparks plugs on a 2005 sonata...and does it need a new gasket
Hi by removing the cover on top of the engine you will see the spark plug wires pull out plug wires and unscrew plugs using a 5/8 socket remember to check the gap on the plug you can fined the gap clearance in the engine compartment good luck
Aug 24, 2009 | 2005 Hyundai Sonata
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
