Question about HP iPAQ h6325 Pocket PC
HP IPAQ Pocket PC
I have a user that wants to know if MSN messenger can be used on the HP IPAQ Pocket PC?
    Master:
  • 450 Answers
Yes it can, in fact it comes pre-installed on the new Ipaqs.
Posted on Sep 11, 2005
I am trying to hook up my hp ipaq model h1910 to my emachine D6419 and it says to hook it up to Com 3 port on the back of my computer. How can I find out where that is on the back of my emachine? I lost...
Connect to a Computer
You can wirelessly connect to your personal computer using an infrared connection.
You can physically connect your iPAQ Pocket PC to your personal computer using Microsoft ActiveSync and a USB cable.
You must have Microsoft Outlook to operate your iPAQ Pocket PC using Microsoft ActiveSync on your computer. If you do not have Outlook, install the Microsoft Outlook software from the HP iPAQ Pocket PC Companion CD.
Microsoft Outlook Express will not work with the iPAQ Pocket PC and ActiveSync.
What book/manual are you talking about?
emachine D6419 can be found at;
http://global-download.gateway.com/GDFiles/Document/User%20Manual/User%20Manual_eMachines_1.0_A_A.zip?acerid=633933437244339685&Step1=DESKTOP&Step2=D SERIES&Step3=D6419&OS=ALL&LC=en&BC=EMACHINES&SC=PA_6E
hp iPAQ Pocket PC h1910 - Reference Guide at;
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002238.pdf.
Good luck and post back.
Jun 03, 2011 | Computers & Internet
I am looking for this update. Is for a old HP PDA 5550. Hp document ID IA01213966. states: The MSN Messenger Software should be updated on any of the following iPAQ Pocket PCs that were either upgraded to...
Chances are, the update is not necessary and may slow it down considerably. However, If you want to update it, you should probably google search for it, although I haven't found anything yet on google.
Sep 14, 2010 | Microsoft Windows Mobile 2003 for Pocket...
Looking for a manual for a HP iPAQ rz 1710 Pocket PC
Look here, and download the user manual you need.
Cheers! Carlos
Apr 30, 2010 | HP iPAQ RZ1710 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
How to connect to the internet
how can i go on msn with my pocket pc model numer 3970 an set it up
Sep 18, 2007 | Compaq iPAQ H3955 Pocket PC
Web pages
Maybe someone has played with your internet configuration in your mobile. try to review them.
Aug 02, 2007 | HP iPAQ H2210 Pocket PC
HP ipaq h6320
Here is a link to the full manual, however it says right in there to not disassemble so you will probably have to find someone's who has done it (maybe on a PDA or Ipaq forum) and ask them for direction. http://user-guides.mobiletopsoft.com/hp/hp-ipaq-h6300-series-user-guide/hp-ipaq-h6300-series-user-guide.php
Mar 28, 2007 | HP iPAQ h6320 Pocket PC
HP iPAQ h6325 Pocket PC Logo
112 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
