Question about Samsung HCN5527W 55" Rear Projection Television
HCN5527W Samsung wide screen 55" will not turn on, scree went black unit 4 1/2 years old
While watching tv the picture went black samsung HCN5527W and would not turn back on red led under power button blinks 9 times then shuts off. Unit will not power on.
  • 2 more comments
  • wsiudym Aug 29, 2008
    While watching tv the picture went black samsung HCN5527W and would not turn back on red led under power button blinks 9 times then shuts off. Unit will not power on. makes 2 second buzz sound when power button is pressed along with 9 blinking red led lights then stops blinking. Will not power on.
    trouble shooting steps:
    1) checed fuse (ok) also checked voltage to unit getting 120vac
    2) no visual burn marks on resistors or any componnts on pcb,s
    Comment by wsiudym, posted on Aug 29, 2008
    Unit is 4 years & 10 months old
    I would like techmans input on this issue thanks.
    Thank you for the manual & advice, I wll try this when I get home from work later in the day, thanks.
    Wayne
  • 435 Answers
If your television does not turn on, try the following:
  1. Check the power cord for breaks, tears, or exposed wires .
  2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
  3. Check the fuse/circuit box and replace or reset if necessary.
  4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
  5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
  6. If you have a DLP TV, click HERE for additional recommendations.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service. To begin the service process, click HERE to fill out an online service request.
For more information, visit this link:
http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=HCN5527W&dType=D&mType=UM&vType=R&prd_ia_cd=02010900&acc_ia_fl=N&disp_nm=HCN5527W
Posted on Aug 29, 2008
  • Narmada Anand
    Narmada Anand Aug 29, 2008
    Please let me know if you need any more information.
    Thanks
    Master:
  • 848 Answers
The fuse might have been blown just check it .........
    Sergeant:
  • 241 Answers
HI it could be somthing simple 1st try
TRY THESE STEPS
>Check the buttons on the TV make sure they are clean and not sticking.
>Check the Remote Control buttons and see if they are sticking
>Clean the Face of the infer Red lens to the remote and the TV...
clean them with a small rag or paper towel (Do Not USE Abrasives to clean any part of your Electronics)
>Check the plug for any defects
>Reset your tv back to it,s factory settings
>And if any thing locate your user manual and find the 1-800 number
(please feel fry to leave a rating)
  • Jayson Brollini
    Jayson Brollini Aug 29, 2008
    Try to reset the tv back to the Factory Default
    >Unplug all devices and try one at a time and see if they all work
    >Or just run your tv with no devices
  • Jayson Brollini
    Jayson Brollini Aug 30, 2008
    Sorry I could not help
    Brigadier General:
  • 3,614 Answers
Check for any burn fuse, and faulty resistor on the power supply area.
  • 5 more comments
  • micromaster
    micromaster Aug 29, 2008
    please add more info on your problem, before you rate us..
    thanks
  • micromaster
    how old is your television now..? did you experience any power surge before the problem happen
  • micromaster
    check the 120k resistor on the video output module.
  • micromaster
    have you done checking the 120k resistor on the video output module?
  • micromaster
    let us know more here again...
    regards,
    micro
  • micromaster
    download manual HERE
  • micromaster
picture tube pro...so pls change ut picture tube and use...and also due to some fluctuation it may cause tis pro so try to plug ur pin in some other slot in ur home
Aug 29, 2008 | Samsung HCN5527W 55" Rear Projection...
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
I have Samsung 46" rear projector TV the TV just went blank
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Televison & Video
Best picture settings for samsung ps50a457p1d
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Mar 08, 2012 | Samsung PS50A457 50 in. Plasma TV
Samsung model number HCN5527W THE PERFECT FOCUS ONLY GOES UP TO 4 PERCENT THEN STOPS THE PICTURE IS HAZEY
You have failed convergence IC's, Have the convergence IC's replaced on the convergence board, Replace them both they are the Large Black IC's mounted on large heatsinks usually mounted on a seperate board above the bottom main boards, The Part # for the IC's are STK-392-040
Nov 23, 2009 | Samsung HCN5527W 55" Rear Projection...
Samsung wide screen HCN5527W tv reset
My Samsung model PS42P3SX/XWU has no sound coming from it from the Sky+ box, just picture. Was working then stopped. DVD connection is ok.
Jun 21, 2009 | Samsung Televison & Video
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
