Question about Toshiba e400 Pocket PC
Align screen
Every time I try to switch my PDA off it comes up with the align screen message. Even after you carry the alignment out it still just comes up with the same message. I end up having to leave it to power off itself. Is there any fix available?
    Master:
  • 903 Answers
I have the same message if the unit is without power supply for a long time but it should not happen every time you switch the PDA on. Maybe is the battery defective.
Posted on Sep 11, 2005
SOURCE:
Every time i try to copy the screen says "press enter to align cartriges
Have you carried out a head alignment procedure, I would carry that out again
the online user manual is available from this link http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=79499&lang=en&
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge. Aligning the cartridges ensures high-quality output. To align the print cartridges when prompted:
  1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
  1. Press Setup.
  2. Press 5, then press 2.
  3. This selects Maintenance, and then selects Align Print Cartridges.
  4. A page of patterns is printed. The cartridges are aligned correctly.
  5. Recycle or discard the page.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
Align Screen stuck in loop after hard reset and clean
Hello, I could be able to diagnosticate your problem but first I need to know some more details. At the current state, can your pda be connected to active sync ? (you may try using it's cradle or usb cable) Can you manage to pass in some way of the align screen message? Does the screen respond to taps? When you tap the screen trying to callibrate does the cursor moves or does something? Please try to explain these questions and I'll be back with an answer as soon as possible. Thanks for understanding.
Jun 12, 2007 | Dell Axim X51v Pocket PC
I have a i-mate jama Pocket PC, yesterday it turn off due to low battery. Today I recharge it but it hang on align screen message..... I have tried several times but all in vain...
you should reset your phone.reset code is 1234.after that "align screen" shows
tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started.
Sep 26, 2009 | i-mate JAM Pocket PC
Align screen problem on HTC P3650 Touch Cruise
try to hold the curser where ever it goes for some seconds after 3-4 tries ur device will start proceeding.
Sep 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc touch diamond non responsive align screen after hard reset
pda requests align of screen until you do it, if you cannot pass through aligning, you could have you digitizer broken, than you should put it to service
Jul 01, 2009 | HTC Touch Diamond Smartphone
I cant get past the align screen on my o2
When you don't charge your PDA's battery for a while, and let both normal and backup batteries to finish completely, all your data in your PDA is lost, and it will go back to factory default state. As the operating system is stored in the ROM of your PDA, it will be reinstalled when you charge it again, and becuase there's no data left from the past state, you have to do all the settings again from the start, beginning with the screen alignment (You can tap carefully on the plus sign each time it moves). If you had a backup syncronized with your PC, you can then recover your data to your PDA.
Apr 09, 2009 | O2 Xda II mini
Align screen
ur Touch panel or in other word Digitizer is faulty try getting it replaced it is around 60 or 70 $ , if u dont want to spend money right now and just want to get rid of this screen alignment process just google 'bypass screen alignment ' there is a utility for that just connect ur pda using usb cable and bypass this process but u will not gett correct response when u touch the screen u will get mis aligned response if u want to get rid of this u have to spent money on hardware replacement
Feb 21, 2009 | HTC PPC-6800 Smartphone
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
Problem with touch screen
Re-align your screen.
Start Menu->Settings->Screen Align screen.
Jul 04, 2008 | HTC Touch P3450 Smartphone
Toshiba e400 Pocket PC Logo
171 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
