Question about Navman NavPix N40i GPS Receiver
Attaching to windscreen
I cannot get my navman to attach to the windscreen properly. What is the trick to doing this I have tried everything and now attach it with bluetac. It is so annoying when I have paid nearly $800 and it keeps falling off the windscreen. Can you help . I have a N-series with smartST 2006SE navnam
    Problem Solver:
  • 5 Answers
HiI had this problem myself - other than going to the expensive option of getting a new suction cup, inspect the existing one carefully, and if here is no crack or break in the cup the problem could be caused by some slight distortion of the suction cup caused by it resting on other items in the glove box or similar. the distortion does not need to be much to stop an airtight seal. Here's the solution: Get a bowl of boiling water, soak the suction cup part of the cradle in the boiling water for a few seconds until it goes slightly soft,  remove it from the water and quickly, dry the part. Next quickly (whilst the plastic is still soft) apply the suction cup to the windscreen in the method indicated by the manufacturer -and that is it! The water softens the plastic so that it can be pulled into place by the vacuum of suction cup mechanism.
Hope this is of help to you or anyone with a similar problem
Cheers
KevTWale
Posted on Mar 17, 2009
  • 3 Answers
I have a spare window mounting bracket as new , but I need SmartST 2006 SE CD Rom. If you want to do a swap , that is you send me a copy of SmartST 2006 SE and I send you bracket email me at
fuddlebarklard45@hotmail.com
Posted on Dec 13, 2008
Bumped the interior rear view mirror and the mirror section has detached from the base which is still stuck to the windscreen. It does not seem to easily reattach to the base.
There should be a small allen screw on the "windscreen" clip. Back it out, attach mirror and then tighten it back up.
Good Luck
Feb 14, 2015 | Cars & Trucks
My navman icn 520 wont find a gps signal and just keeps waiting for gps
I found that if you open out the receiver at the back and make sure it is touching the windscreen it works for me. If not I don't get a signal. It is worse in one of our cars because it has a heat reflective windscreen.
Feb 05, 2013 | Navman iCN 520 GPS Receiver
My Navman continues to not stick to the windscreen the plastic pad just doesn't want to stick what can I do?
hi,
Seems you have a faulty suction mount. If your device is still under warranty, contact Navman, they should be able to replace it for you. If you're outside warranty, you would need to purchase a new one from the Navman Store (http://www.navmanstores.com/)
Feb 25, 2011 | GPS
Drivers side windscreen washer not working, whats wrong? washers are attached to wipers
there is a pipe attached to the nozle which spray the water get clotted remove it and then try running the water if the water comes out then pin in the nozle to open it
Feb 04, 2011 | 2006 Jaguar S-Type
Cant connect to my navman m 400 to my computer
Open your MioDesktop, attach the navman to computer via usb cable provided with it when you purchased...make sure your firewall allows you to connect to mio server.
Nov 24, 2010 | Navman Mio M400 Car GPS Receiver
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
My interior rear view mirror fell off. How do I re-attach it back on to the bracket which is still attached to the windscreen. I own a 2006 VW Polo. Help, please?????
Well known issue on VW cars.Try to use 2 component glue to fix it like Diamant or Epokit.You may need to create a holder while glue goes off.
Jul 15, 2009 | Volkswagen Golf Cars & Trucks
External Antenna Conection
Ref ICN330. The external antenna connection is on the top side of the flip up Antenna on the unit itself. There is a small rubber plug covering this, adjacent to the Navman logo.. Ricmac
Feb 12, 2009 | Navman iCN 330 GPS Receiver
After putting in starter, attaching wires is HARD, any tricks to attaching wires??
You got it, we attach the wires first as you already figured out, just make sure the battery is disconnected for safety sake.
Oct 14, 2008 | 1996 Chevrolet Suburban
Attaching the device
YES , try EBAY , search for tomtom vent mount. You can also buy special rubber disks that have a sticky back. The disk can be attached to the dashboard or some other plastic area. These allow the normal tomtom windscreen mount to fix to the disk.
Jan 30, 2008 | Tomtom ONE GPS Receiver
Navman NavPix  N40i GPS Receiver Logo
243 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
