Daewoo ds608p cka not picking up a signal have scanned several times but not finding any channels?
I have not resolved the problem i am waiting for you to come back to me! I was given the option of signing up for the premium plan which i declined so presumably i will not get the free advice offered?
Posted on Aug 29, 2008
Missed channels
Those particular channels are not being detected because of antenna orientation or weak signal level. We have similar problems receiving digital channels 3, 6, 23, and 52 here in the Philadelphia area.
Jun 08, 2017 | RCA Dta800b1 Digital-to-analog Converter...
Why is the tv not finding channels when channels are scanned?
make sure your tv is set to pick up the signal it could be cable digital or analog channells.there should be an option for this in the menu.
Jun 04, 2012 | Scott LCT37SHA TV
My samsung ps42c91hdx/xsa tv wont tune in the high def channel 10. the tv can't find it. My sons tvs are picking it up so it cant be the signal.
go to MENU, SETUP,
There you can reset to factory settings. After you set the clock and date, it will ask to scan for all active channels and it will block out the channels it does not find a signal for. Let it complete this task (20 minutes). It asks you for the type of signal but just leave the STD setting for both options before starting the channel finding routine.
When complete, go to channel 10 to see what show is on (low def version). then click down to channel 2 and then push the channel down button several times again to try and find the HD version of that show. (HD channels are high-number channels that are easiest to get to by scrolling below channel 2. Most will have a hyphan in the channel name (e.g. 93-2; 94-1, 94-2, ...).
If your TV goes directly to a 2-digit channel, they you do not have an HD tuner in your set. I doubt that is true so I think you will find what you need.
Let me know if it doesn't work.
May 06, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Channel scan only finds 1 channel with basic cable setup on LG 42LD520
if you have a cable box just plug the cable box into a scart socket on the tv, switch the tv to the scart input and use the cable remote to change channel?Scanning for channels wont find anything because you are receiving the channels on a cable box. If you are refering to standard or digital tv signals and your not receiving any channels then either you are only scanning analogue tv and therefore wont pick up any digital tv channels, or your ariel is inadequate to receive an acceptable digital reception and will need to be upgraded. please state country you are in and what you are expecting to receive
Apr 13, 2011 | LG 42LC2D 42 in. LCD HDTV
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
I have a Daewoo DS608P Freeview box which will not detect any chennels. The pre=scan and scan appear normal, but nothing is detected. The TV, which has no Scart socket, works fine on analogue, and I have...
Sorry to be the bringer of bad news but the transmission mode in the uk is changing & that is why your box will not pick up any channels have a look on http://www.freeview.co.uk/help/faq/id104963 I'm affraid your box is finnished.
Jul 25, 2008 | Televison & Video
No channels can be detected have tried 2 Daewoo DS608P boxes connected to same telly but same thing happens. Signal strength seems fine boxes have been working fine for years.
I am the same. Not a sausage from my same model Daewoo freeview box today. Scans and re-scans and not a single channel to be detected.
Rob
Jul 05, 2008 | Televison & Video
Red flashing light and no channels on Daewoo DS608P
blinks red light then with sound for a couple of second, then turn off by it self no light on the projectorlens
Jul 02, 2008 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
