Question about Sennheiser HDR 120 Consumer Headphones
Wrong voltage usage
I just bought a HDR 120 recently through Amazon. I plugged the 120V tolerance head phone plug to a 240V power source which of course cause it to breakdown. It was a careless mistake that i made without reading the instructions properly!
I would like to enquire whether this product is protected by circuit breaker or fuse to prevent damages from current surge? Does the damage extend to the components within the transmitter? How do I fix this problem?
    Genius:
  • 1,011 Answers
Sir/madam,
They have no fuse / circuit breaker. And also u can't claim any warranty for the product so, better to contact customer care for more details.
The following cases are not covered by the above warranty:
faults resulting from improper use (e.g. operating errors, mechanical damage, incorrect operating voltage)
contact us by mail at:
1 Enterprise Drive
Old Lyme, CT 06371 or Phone: (860) 434-9190
or else contact Amazon for replacement.
thanks
good luck
Posted on Aug 29, 2008
  • 13,433 Answers
Hey,
Generally, headphones and other small entertainment devices don't have fuses in most cases. I feel the best solution is to buy a new set, as I don't think warranty covers such user mistake.
Thanks,
Ekse
    Genius:
  • 1,847 Answers
I dont think there is any sort of circuit beaker or fuse involved in the unit.
    Brigadier General:
  • 6,966 Answers
Most electronic devices have some sort of fuse or fusible link or sacrificial component in the event of voltage spike/transients. However, in your instance, the voltage was practically doubled and it is very likely that other than the fuse, some other component may have been damaged.
Checking/repairs would involve opening the unit. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 435 Answers
I dont think there is anything which you could do here. The best thing would be to call them and ask if the product can be serviced, probability is very less though.
Regards
    Genius:
  • 1,011 Answers
Dear,
check its circuitry. most probably, it doesnt contain fuse but check it by the way.
regards,
dont rate it until satisfied
How to change the voltage for Yamaja YSP4000 from 120 V to 220 v
The US and Canadian models are fixed voltage - 120V 60Hz. There isn't a model sold anywhere in the world that is multi voltage. The European model is 220~240V 50/60Hz
If you want to take this product abroad with you, then you will need to buy a Step Down Transformer. This will take 220~240V and convert it to 120.
The power consumption of the YSP4000 is 55W. You should over specify the Step Down Transformer by at least 20% to ensure there's enough current when the speaker needs it. 70W minimum should cover it.
Aug 04, 2014 | Yamaha YSP-4000 Main / Stereo Speaker
What sort of step down transformer should I buy to use the cuisinart hand blender (US plug), in the UK?
http://lgcdn.220-electronics.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/5/0/500-watt-voltage-transformer-regulator-type4.jpg
It is actually a step-up transformer you need- from 120v to 220 v.
There are many of these transformers or converters listed on the web. Do a search " 120 v 60 hz to 220 v 60hz converter. "
The critical feature is to have a converter that has a wattage rating equal to or greater than the appliance that is plugged into the converter. It is best to a converter with a higher wattage rating than the appliance beacuse most appliances have a surge of current at initial startup.
May 05, 2014 | Cuisinart CSB-79 Smart Stick 2-Speed...
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
The Philips Norelco Bodygroom BG2040, does this model support multi-voltage charging ie. 100v - 240v? Or is it only 100-120v?
Welcome to Fixya,
According to the manual of The Philips Norelco Bodygroom BG2040, use only the cord and charging stand that was provided. Also you just have to plug the adaptor into 120V AC outlet.
If you want to know more about your Philips Norelco Bodygroom BG2040, just click here for the manual.
Hope this will help you and answered your question.
Thank you for using Fixya.
Feb 23, 2011 | Norelco Bodygroom Men's Total Body...
Dear sir I am trying to connect Model Et104, my questions are as follows: I am having a problem connectiing your system. Both power source 110v and 220 volts have to connect to your system???? If my...
Fixya answers questions about other people's products.
I specialize in timers.
Intermatic is changing their product line
I suggest you download the manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
The manual is generic across all the ET100 series products.
The manual does not describe individual models.
The instructions are on the timer door.
Look for the clock voltage.
The clock voltage tells the story of your timer model.
NOW lets say your clock voltage is 120V.
I believe you suspect the clock voltage is 120V.
To make this timer work with your 240V cable, there are 2 methods
Method 1) To meet code, run a white wire from nearby 120V receptacle.
This is a Neutral wire.
Connect the Neutral to terminal 1
Connect one leg from the 240V cable (1 of the 240V wires) to terminal 2 and that will complete the 120V circuit and the clock will run.
This is true because each leg of a 240V circuit is actually 120V, and only when the two legs are combined do they produce the 240V circuit
Method 2) Connect bare ground wire to terminal 1 and to grounding screw
The bare wire connects to the Neutral busbar in the main breaker box, so it will complete the 120V circuit just as described above.
This is not code, but your clock will operate.
Then connect one leg from the 240V cable to the terminal 2
IF your clock is 240 V, then connect both legs of the 240V cable to terminals 1 and 2
7:59 CST Add a comment if you need more assistance, I will be here later this evening
Nov 06, 2010 | Intermatic INC ET104C 24 HOUR ELECTRONIC...
Change the voltage from 240v to 120v
Unless there is a 240/120 switch on the back, this amplifier cannot change voltage. The only way is to replace the power transformer, and when you do that you need to use the exact model transformer Peavey uses for the 120 version. I have also seen differences in handling power outside of just a different transformer for USA/Euro models.
The differences between these two market models might be beyond what is cost-effective to convert.
If it is the Peavey blazer 158, they go for as cheap as 100 bucks here in the states. Or buy one new for 120.00 bucks and 4.99 shipping: http://www.dcmusicstore.com/Peavey-blazer-158-guitar-amplifier
Best advice: sell it for what ever you can get and buy one here.
Hope this helps!
-mike
Mar 28, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Plugged US purchased Wii into Europe outlet with an adapter and n
You would need an adapter that not only runs at 120 or 240 volts, but also one that OUTPUTS 120v. The Wii may have some kind of protection in it if you're lucky (most people don't hook up US Wii's to 240v). But if not, you've killed your Wii. Check the adapter, if it has a fuse that's removable you should see a (usually) circular cap kind of thing on the brick you can unscrew and pull the fuse out.
As for what you would need to purchase, it would be something like this: http://www.amazon.co.uk/Step-down-voltage-converter-240V/dp/B000L99ZJ2 would work perfectly. The Wii only draws at maximum 30watts and this unit does 100. Your TV on the other hand would need a higher wattage unit.
Jan 08, 2009 | Nintendo Wii Console
Microwave fuses
Just replace the fuse Brother. No harm done. BUT, keep it away from your wife. Maybe she's thinking doubling the voltage would make it twice as fast. NOPE!!!
May 02, 2017 | Sharp R-930AK Convection/Microwave Oven
Electrical requirements for a Nexxt MO# WTMC 5321US
it would be simpler and cheaper to get a new dryer
most of the world uses a single phase 240v 50hz system, your dryer is designed to run on a 2phase 120v 90degree system.
the common statement that high voltage items like dryers use 220-240v is not strictly true, instead they run off both 120v phases of the 2phase system.
A transformer to produce a 2phase 90degree 120v 20A secondary from a 240v single phase source is expensive and very large.
It would be cheaper by far, to sell the dryer, and replace it with the equivalent model built for 240v single phase, than to buy the transformer and ship the dryer.
Sep 13, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Sennheiser HDR 120 Consumer Headphones Logo
249 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
