Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Xp sp3 wireless not working properly
I allowed xp pro to download sp3 and afterward my wireless connection would not complete the the wpa link. I have since turned off the wpa in the router and the link works. When I turned it back on the same problem returns.
  • wmtelsr1 Sep 01, 2008
    This was very informative. I couldn't download the listed fix. I tried to restore back and found it made it worse. I un restored and had to reload the wireless card's driver. I found that it worked after that. I don't what you did but it works now
    Thank you
    William Linn Sr.
  • 928 Answers
You can try this WPA patch for SP3
http://www.microsoft.com/downloads/details.aspx?FamilyId=009D8425-CE2B-47A4-ABEC-274845DC9E91&displaylang=en
If this does not work you can revert back to SP2 by
Click start then control panel then go to add/remove programs. Look for Service Pack 3 and remove
If that does not work you can also do a system restore by
Click start then run then type in msconfig
Click on launch system restore.
Restore to a date before your SP3 update.
Note: All other installations after this date will be lost
Your files will NOT be lost
Posted on Aug 29, 2008
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
Drivers free download pro wireless 3945abg driver driver version 11.1.1.11 xp sp3
you can download 3DP Chip v11.12 from Mediafire
Open it,and you will found Your driver like Example on the screenshoot,and Click it,you will Redirect to the Driver you've need.
Please don't forget to rate it if this helpfull.
Dec 10, 2011 | Intel PRO/Wireless 2200BG 802.11g/b
FUJITSU LIFEBOOK S6010 - INTERSIL PRISM PCI WIFI CARD - WPA LAN
Seems like you have a pretty old laptop. I'm guessing its got a wireless B card installed internally. And wireless B supports WEP most of the time. And if you're lucky the manufacturer of that wireless card may have an update to patch your card so that it will see WAP. Otherwise you can replace that internal card or get a usb / PCMCIA wireless card that supports at least wireless G standard.
Jul 29, 2009 | Fujitsu LIFEBOOK S6010 Notebook
My Toshiba Satellite A55 S106 wont allow WPA2 which is what my internet uses..how can I fix this or is it hopeless?
If this is for XP, you need to update to SP3 which has WPA2 support now. Vista comes with it anyway. You might have registry issues if SP3 WPA2 fails to install properly. You could also change you router WiFi security to WPA or WEP.
Jul 24, 2009 | Toshiba Satellite A55-S106 Notebook
XP SP3 doesnt allow driver to get loaded
not a problem in xp sp3 under the device manager in system properties you will have a yellow circle and black exclamation mark and probably say unknown device or ethernet device. right click go to properties and in details tab you will see Device ID.. we can track OEM driver from this.
Jul 24, 2009 | Intel PRO/Wireless 3945ABG Network...
Can't get the d-link adapter to work on wireless windows xp comp desktop when the internet comes on it bumps me off
1. Might it be that a security configuration setting in you router is preventing you from connecting to the internet?
Check the WEP or WPA settings; the set type of network (B, G or both), MAC address filters, etc.)
2. Download the most updated driver for you adapter from D-Link support pages. The last service pack for Windows XP (SP3) turned some adapters (DLink models too ) unable to connect to internet. The driver update will solve the proble
Jul 18, 2009 | D-Link Computers & Internet
Sp3 and wpa2psk wont install
Particularly I think the problem is not in Wi-Fi connection for your laptop, but the configuration of your router, try using wpa security checks and only connection, besides if you give before you upgrade the service pack, the connection works properly. Additionally if you give before you upgrade the service pack, the connection works properly.
May 07, 2009 | Toshiba Satellite P105-S6104 Notebook
Need WPA2 wifi connection to my Linksys with Dell D600
The WPA settings on your wireless card must be the same as the setting you configured on your wireless router. This allows your wireless card to communicate with the wireless router.
Apr 07, 2009 | Dell Latitude D600 Notebook
Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
451 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
