Question about Olympus Camedia C-3040 Zoom Digital Camera
Lens Protection Size!!!
What is the lens size of Olympus 3040Z digital camera. Also does anyone know what kind of lens protection is best.
    Master:
  • 852 Answers
Just another option: I have the 3040 and the Tiffen adapter tube (3000AD). 43mm UV fits right on the tube (my UV is a Tiffen as well)without need for step up ring. 3040 lens cap fits UV fine. Olympus couldn't have done it better.
Posted on Sep 11, 2005
    Master:
  • 852 Answers
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
SOURCE:
Hi, I have a Canon Ixus 70. Had it for several years. Suddenly the lens protection does not open when I start the camera, or opens only half. This is no lens error. The lens is behaiving normaly and...
hi! there is something wrong with your camera lens or the parts around the lens like the bayonet or flex cable. so it is better replace them or send to some professionally maintance center such as www.skiliwah.cn/
http://www.digitalcamera-parts.net/
MSN:e-8090team@hotmail.com
Aug 17, 2011 | Canon IXUS V2 Digital Camera
Dear FixYa, I got an Olympus E-620 camera. Recently a friend of mine who owned an old SIGMA AF lens ( w/ Olympus mount ) wanted to release/sell it to me. Could this lens attached to my camera with or...
As an Olympus user myself, I would not advise even if you could find an adapter. Your 620 is a 4/3 series camera with is a different frame size than the old 35mm equipment which means you will not get ideal photo quality. Yea, new lens are expensive, but losing good shots to sub par equipment costs you more in the long run in frustration.
Dec 27, 2010 | Olympus ED 35-100 f/2.0 AF ZUIKO DIGITAL...
Size of uv lens filter
Can you give me details of what kind of lens you have, Brand/Model with the F-stop size. Tony
Jun 03, 2010 | Olympus Cameras
What size uv filter do i need for an olympus sp-570uz camera ?
The SP-570UZ does not have a filter thread; therefore, lens filters cannot be attached directly to the camera.
Filters with 55mm diameter can be attached to the SP-570UZ via the CLA-10 Lens Tube Adapter, sold separately. However, it is not recommended because vignetting may occur in the corners of the image when the camera is set to wide angle positions.
The CLA-10 Lens Tube Adapter (Item #202104) is available from authorized Olympus dealers and also online from The Olympus Store: http://emporium.olympus.com
Apr 26, 2010 | Olympus SP-570UZ Digital Camera
How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Mar 08, 2008 | Olympus Camedia E-10 Digital Camera
Macro lens for the 3040Z
I have very good experience with the original Olympus Macro Conversion lens with the CLA1 adapter. No visible distortion and no loss of contrast. The only problem I can imagine is the lighting of it all. You need to come real close! The internal flash of the camera will not work properly because the "huge" macro lens will cast a shadow. Some kind of external light source will be needed and manual corrections in the white balance have to be made too. The 3040 is a fine camera and I use it at least twice a week, but it still lacks some of the features of my old OM4 camera! Think about the easy focusing (manual) and the use of a ring flash! Because that is what you need.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Filters
Yes, the Olympus E-20N has a 62mm filter thread size. You can attach a standard 62mm lens filter directly on the lens. Color filters would not have an effect on the camera due to the auto white balance.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Olympus Camedia C-3040 Zoom Digital Camera Logo
139 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
