Question about Kenwood VR-309
Vr-309 starts to clip after 10-15 min
My VR-309 has recently started to distort and clip the audio being output after it warms up, Usually about 10-15 min. Occasionally when adjusting the volume the sound would be overcome with static while the volume was changing. I found a cold solder joint related to this problem and have not had this issue since fixing. The distortion from the volume knob and the eventual warm up distortion sound identical. I am not sure if they are related
  • 4,234 Answers
This is a case of one or more transistors breaking down when heated. This can be found usually by using freeze spray to cool down one transistor at a time until the problem clears up. You can narrow this down a bit by determining whether this "noise" is effecgted by the volume control or not. Also, does the problem show up faster when the unit plays louder?
Dan
Posted on Aug 29, 2008
I have a kenwood Auto video surround receiver DR / 409 how to reset it
PDF]KRF-V8030D VR-409 - Kenwood
manual.kenwood.com/files/B60-4593-00.pdf
VR-409. INSTRUCTION MANUAL. KENWOOD CORPORATION. B60-4593-00 (EN) ...on the country and sales area. AUDIO VIDEO SURROUND RECEIVER ...
Kenwood VR-409 Manuals
www.manualslib.com > Brands > Kenwood Manuals > Stereo Receiver
View online or download Kenwood VR-409 Instruction Manual. ... Kenwood Instruction Manual Audio Video Surround Receiver KRF-V8030D VR-409.
Kenwood VR-409 Receiver Repair Questions, Solutions ...
www.fixya.com > Forum > Audio & Video Receivers > Kenwood
Recent Kenwood VR-409 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
Kenwood VR-409 PDF Owner's Manual Download & Preview
www.manualguru.com > Kenwood Manuals > VR-409
Feb 03, 2016 | Kenwood Audio Players & Recorders
I need help trying to set up the surround sound for my vr-390 receiver. i have two two large side speakers. a large middle. and a subwoofer i cant get to work. (all kenwood) i also have 2 bose surround...
Manuals help. Read them. Nothing in your receiver is actually a multichannel source so you'll be needing to understand the external sources that originate that kind of programming. Manuals.
Here's one...
http://www.retrevo.com/support/Kenwood-VR-309-Receivers-manual/id/480dj195/t/2/
Try the other manufacturers' support sites for your unidentified gear, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
'Large' is not literal in the context of Bass Management. It refers to the ability of a given speaker to handle REAL bass. Yes = Large, No = Small. 'Small' redirects bass from that speaker channel to the sub.
Web search concepts like bass management, speaker placement, multichannel sound, digital audio, etc.
Sep 05, 2011 | Kenwood VR-309
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
Jun 10, 2011 | Kenwood VR-309
I have a vr 309 kenwood reciever with a bad subwoofer port because sub doesnt produce sound through it but does through another reciever, is there a fuse or capacitor just for this output i can check or...
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
Dec 05, 2009 | Kenwood VR-309
VR-206 - how to wire in equalizer
your vr-206 have several inputs dvd, vcr, tape decks, turn tables etc, also have an opcion called eq in and out usually if you dont have an equalizer al you do is jump straight rca to rca cables red in to red out and white in to white out.
but if you have an eq all you do is output from amp vr-206 to input and the input to output back to the amp
Dec 22, 2007 | Kenwood VR-209 Receiver
Surround sound not working properly
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Oct 27, 2007 | Kenwood VR-309
Kenwood VR-309 Logo
115 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
