Question about HP iPAQ RX3115 Pocket PC
Resetting Date Hi, iPAQ date setting has moved ahead by 24hrs. Please e-mail any helpful information to reset this program.
    Master:
  • 450 Answers
In Activesync, under Tools, Options.
Posted on Sep 11, 2005
I need help resetting the date and time on my Celestron super weather station. There is a label that says 433MHZ
Hi Richard do not own one of these stations but normally you can obtain instructions on line or try to contact the manufactuer
Mar 11, 2015 | Celestron Measuring Tools & Sensors
GPS 38 unable to access date and time in system setup. presently shows 1 jan 05
Hi John921,
Here is the step by step procedure to set date and time of your Garmin GPS 38......
It will definitely work......
Set Local Date and Time
1) Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2) Move the field highlight to the OFFSET field
and press Enter
3) With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4) Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
This will definitely work......
Please rate this solution............
Thanks......
Sep 08, 2008 | Garmin GPS
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Invicta model 4562 7750 valjoux automatic movement. Day and Date are difficult to set. Move crown to second (B) position, sometimes the day of the week adjusts, then the date will not adjust moving the...
Hi Friend,
Please check with the below link,which gives the detailed information about the Invicta Watches.How to set the Date and time in your watch.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
If you have any Clarification please write back to us
Regards,
Aysaam
Jun 13, 2010 | Watches
Unable to get yahoo mail.
Re the "error code sec_error_expired_certificate" that I got when trying to access Yahoo mail from Mozilla--turns out the date and time on my computer had reverted back to Jan.2001. Discovered it by accident when setting the time on my watch to the computer this afternoon and computer time showed AM instead of PM. After resetting time and date, no problem getting Yahoo mail. I figure the battery probably needs changing.
Dec 30, 2008 | Yahoo Mail
HP iPAQ 5555
after full reset I am unable to access online capabilities
May 06, 2008 | HP iPAQ H5550 Pocket PC
Ipaq h6365 automatic shut down and reset
if i use camera,pda kan be use because hang
Apr 21, 2008 | HP iPAQ h6315/h6365 Pocket PC
Reset
what is the problem exactly?
the date resets to 11 2005 and then the whole phone restarts?
what?
Thanks
Mar 25, 2008 | HP iPAQ h6325 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
23 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
