Question about WYSE Winterm 3235LE Network Terminal
Problem with WYSE Winterm 3235LE
It displays Over frequency problem, unable to go further.
  • JuniorRon Aug 29, 2008
    This is the exact problem:
    Over frequency
    H:91.2KHZ V: 85.1HZ
    Eargerly waiting for your help.
  • 3 Answers
Tsaukpaetra is correct it's a resolution mis-match with the monitor you are using. If you have Rshadow loaded on the winterm you can VNC into it and change the resolution. If not you can hold down the letter "G" on the keyboard to perform a factory reset.
Posted on Dec 16, 2008
You monitor cannot support the frequency that the terminal is set up to display at. You should try hooking up the terminal to another monitor that can support 85Hz, set the terminal to display at a lower frequency (control panel -> display) and try it again.
If all else fails, you should be able to reset all settings to the factory default (if you can't find a compatible monitor) by pressing and holding the Reset button (check the user manual).
Posted on Dec 13, 2008
Websites are blocked im on my school computer
Of course the are !
The school staff don't want you wasting your time and their resources in social networking, so most probably you won't be able to access Facebook, Twitter and the like.
Jun 02, 2010 | WYSE Winterm 3235LE Network Terminal
Purchased used wt9235le and don't know logon id or password,how do i crack
Hi, if it is similar to the 3235LE you can reset them by holding down the "p" key whilst powering on the device.
Jan 20, 2010 | WYSE Winterm 3235LE (90202401R) PC Desktop
Screen freezes
It is Link to network down
or ip address is conflict to another machine in your LAN
check ethernet cable
Jun 03, 2009 | WYSE Winterm 3235LE Network Terminal
I have a WYSE 3235LE thin client in a Sears retail environment. I need to reset the bios. There is a way to flash it from another terminal but the bad box won't boot. It stops with keyboard/mouse error....
The best solution for resetting the bios is to do a hard restart. This requires you to get to the motherboard and take out the battery for about 15-30 seconds before replacing it. By doing so, the temporary memory in the BIOS is erased and you will have you factory settings.
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
How to disable auto login on 3235le
Hit the ALT key and F4 while auto logon is counting down to cancel auto logon.
If you've forgotten the admin password you can perform a factory reset by holding down the 'G' key while powering the device on.
Nov 20, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
Wyse 1200LE - error - out of frequency
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Apr 02, 2008 | WYSE Winterm S30 Network Terminal
Unusual problem
Perhaps the systems have accumulated dust on the inside, and therefore the unit could be overheating.
Oct 16, 2007 | WYSE Winterm 3235LE Network Terminal
I have a 3235le with wince 2.12. How can I upgrade the RDP client to 5.1 or 5.1+?
I tried to do the same thing but ran into the same problem - I gave up. However, I have been successful in loading RDP 5.1 onto a Wyse 8235LE. Works great with full resolution RDP sessions!
Sep 03, 2007 | WYSE Winterm 3235LE Network Terminal
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
Wyse wt3235le running on windows 2000 server
OK What ya do is right click the desktop and go down to properties.. open this and there ya should be able to adjust ya resoloution and colour... It's max is 1024 x 768.
Jun 03, 2007 | WYSE Winterm 3235LE Network Terminal
WYSE Winterm 3235LE Network Terminal Logo
502 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
