Question about Whirlpool GHW9400 Duet Washer
How do i fix?
Wont spin and getting blinking f11
  • vtmi Nov 05, 2008
    Starts, beeps six times begins to fill then blinks F11.
    Machine used ten times but two years old. Vacation home.
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%
Posted on Sep 29, 2010
F11 CODE AND TUB WONT SPIN
It may be the door assembly
http://www.repairclinic.com/PartDetail/Door-Or-Lid-Latch-Assembly/8182634/1094190
In the owners manual, it describes the issue, and possible fixes. its a communication error, and could also be due to something as simple as unplugged or loose wires.
Jul 24, 2014 | Whirlpool duet Washing Machines
Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
The F11 error can be difficult to resolve even for us technician's.
The F11 error occurs when the central control and motor control don't talk to each other.
If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
When the washer goes into spin cycle, it makes a very loud noise and then the spin cycle stops and F11 appears on the screen
This just happened to me tonight too - but I ddint get the F11 code.
When I stopped the machine, there were small plastic threads everywhere and when I investigated - the white plastic ring that is covered by the gasket - if you pull the gasket back you can see it - was shredded! I am afraid of the cost to fix this one. My machine is about 7 years old. Is it fixable - or should I give up?
Jun 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Blinking f light
any fault codes f11, f02, sud, ?????
Jul 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Getting F11 code r8ght after starting,then flashes and stops
usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Dec 10, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
