Question about Sony Televison & Video
I have a sony kv-27fs12 tv shut off on its own, now when try to turn on it makes a rapid clicking sound, like a gas stove ignitor,for about 5 seconds then shuts off and stand by light flashes code 4. have tried unplugging for 24 hours and longer. still wont turn on and flashes code 4
    Genius:
  • 2,035 Answers
If your sony tv is as flashing lights :
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television
Certainly, I can help you. I would recommend going to the following link and getting the service manual so you can see first hand disassemble instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new board. heres the link.
http://servicemanuals.vstore.ca/
Good luck...
Posted on Aug 29, 2008
  • Sony Master
  • 6,487 Answers
Blinking 4 times,
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped. This problem should be handle by a repairman already..
Hope that helps......
  • 4,472 Answers
How long have you owned the unit? You will most likely want to have it serviced by a professional. You can locate the nearest authorized center here:
http://eservice.sony.com/webrma/web/index.do?SR=nav:service_support:electronics:repair:esup&ref=http%3A//www.sony.com/index.php
If you need any further assistance let me know.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 29, 2008
    It sounds like a vertical amplifier problem part usually around 100$. I would still try and contact sony for an estimate.
    Thanks,
    Lee
I have a Sony kv-27fs12 the picture go out but you still can hear it and the standby light turns on first it flash 5 times then stop and do it again now flash continuously please if you know let me kn
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. If you want to know more about the blinking codes to Sony Brand TVs, check this link.
Jan 14, 2013 | Sony KV-27FS12 27" TV
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
Hi I have a sony Wega tv model # KV-27FS12. When i turn the tv on this is clicking sound and the tv has no picture. The tv automatically turns off after ten seconds or so. The sand by light flashes 4...
G'Day!
The TV can be fixed as long as the parts needed are still available from Sony. However, as far as trying to determine what part(s) are needed, I wouldn't listen to anyone other than a tech who's actually taken a look at the set or has worked on one with the exact same problem. If you make a call to a local repair shop, especially one that advertises repairing Sony, a nice guy will at least give you a ball park figure as to what the repair will cost you.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My stove works and so does my broiler. I replaced
If you use a multimeter, you can test the gas valve where the white and yellow wires connect is where your terminals for bake on that valve are. If you have continuity there, then check to make sure that igniter is wired ok.
http://tclaundryrepair.com/home
Feb 19, 2009 | Whirlpool SB160PEE Gas Single Oven
No Power Sony KV-27FS12
IF the unit is completely dead (no standby light at all) then teh main fuse is most likely open. Try replacing that first. If the stnadby light is on, then when you attempt to turn it on, the light shouild blink. If so, the blinking should be a repeated count with a short pause between sequences. Post that count here as it will indicate what circuit has the problem. We will continue from there.
Thanks,
Dan
Feb 11, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-27FS12
hi there, there is a problem at your power supply section. do some test, it maybe a electronic part faillure. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
PICTURE TROUBLE ON SONY TV ..KV-27FS12
most sony tubes bow in the corners, they just arent built that well
Apr 11, 2006 | Sony KV-27FS12 27" TV
Televison & Video Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
