Question about Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
Bread toaster doesnt work
My parents just bought this toaster and threw away the box. The bread toaster doesn't heat up.
  • 3 Answers
It could be the slide button connections or loose wires. You would have to take it apart to try and figure it out. It should be under warranty, though. I don't know if the box is required. You'll have to ask Back to Basics about that.
Posted on Oct 10, 2008
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Do I have to wait for the toaster to warm up or put the bread in then switch on
Letting the toaster heat up first before putting in the bread is really just a waste of electricity and is unlikely to improve the efficiency of the machine or the quality of the end product in any way.
Just stick the bread in and then turn the toaster on and it should work fine. Within a short time you will learn just how long you have to leave them in so that they are toasted properly according to your own personal tastes.
Good luck.
Jun 14, 2011 | Kitchen Appliances - Others
Try cleaning the bread crumbs out of the thermostatic release mechanism. If necessary, lubricate the slides with a light, high temperature grease, but apply it very sparingly.
Jan 16, 2011 | Kitchen Appliances - Others
What is back to basic toaster?
Toaster of the first order wherein there is only the heating coils arranged on either sides and the bread is loaded on the slits to be pressed down to hold on.
When the set temperature is reached then the bimetal switch releases the lock and releases the bread up.
This is the basic model with no electronics inside.
Aug 25, 2010 | Back to Basics Kitchen Appliances - Others
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Problem with toaster
Did you try cleaning it? Crumbs in the works can work miracles - against you!
Jun 11, 2008 | Kitchen Appliances - Others
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
if u need instructions on how to use a goes:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster Logo
166 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
L Vincent Testa
L Vincent Testa
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
