3 options..
--your charger is broken ? does it light when you plug in to power outlet ?
--Charger cable is broken ?
-- Your notebook's battery charging circuit malfunctions.(hope not)
Try with another Apple charger from your friend...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
the laptop only turns on with power plugged in
light on the charger is green, also used a different charger with no luck, cable is fine
the battery status states "not charging"
if this is the case 2 option..
-- Your notebook's battery charging circuit on main board malfunctions.(hope not)
-- Your battery is kaput...needs to be replaced.this is easiest problem...
Take your notebook to a electronic shop that you will buy battery and before testing Battery with your charger do not buy it ..you must verify that charging circuit is OK..
Take care..
I had the same issue a few weeks back. I tried using an older magsafe charger because I hoped the battery wasn't the problem. I had the same issue with the older magsafe charger, but it would actually charge sometimes.
I replaced the magsafe with a brand new one and the problem was fixed. I hate to say buy a new charger and then it not work, but I wanted to share how I fixed the issue without having to buy or replace my battery.
