Uniden BC60XLT Handheld Scanner Logo
Anonymous Posted on Jul 21, 2011
Mod BC100xlt --scannes,no sound ,tried squlch&volume no luck JERRY
Patrick Patterson
Level 1:
Habit-Forming:
  • Contributor 41 Answers
  • Posted on Jul 21, 2011
Patrick Patterson
Contributor
Level 1:
Habit-Forming:
Answers
41
Questions
Helped
17107
Points
58
Hello Jerry,
If you have an external speaker or headphones, plug it into the headphone Jack. If you get audio then your problem may be a bad speaker or a problem with the headphone jack. If you still don't get any audio then threre may be a problem with the Volume pot or Audio chip, in which case the scanner will require sevicing by a qualified technician.
  • Anonymous Jul 21, 2011
    thanks JERRY
  • Patrick Patterson Jul 22, 2011
    Please don't forget to rank my assistance
    Thanks
    Patrick
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
2answers
Blue light Slash Wah pedal. After a few weeks the blue light has stopped coming on (I run it on official 18V adapter). Rest of pedal works fine, as before. Would love to have those blue lights working...
First thing to ty is to try it using two 9 volt batteries as a test to see if lights work.
I ASSUME that you are NOT trying to use the pedal in the external effects loop (send and return) as the levels are not compatible. The pedal must be between the guitar and the inout of the amp.
Beyond this I would open the unit and look for something loose or broken where the blue LED is located.
2answers
I want to hard reset my galaxy tap. I have a symbol of phone on left then central yellow triangle with ! and computer symbol on right and holding volume button down with power button nothing happens
THERE IS NO USE OF HARD RESET I THINK THAT MAY BE WRONG WITH UR HANDSET POWER &VOLUME KEY BETTER U GO TO SAMSUNG SERVICE CENTRE
DONT PUT ANY OUT SOURCE IT MAY TEMPER UR WARRENTY
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Tweeter plays and very low volume when in back by
This sounds like I would be trying a new crossover network module.
Jerry G.
Igot a used Uniden bc100xlt scanner and no manual and cannot rece
Go to uniden's website for literature or call small electronics shops for repairs...Most wont work on those units as they are too old. I have a uniden BC100XLT from 1988. I had to buy another one off ebay for parts. Also look for info on the BC200XLT as it was an almost identical model. Finally the batteries corrode and certain transistor pop in these early models, check the battery first. open it up and make sure the wires are still connected to battery.
1helpful
Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
I have no sound coming out of my cumputer speakers
Check to see if the drivers are installed correctly. Check to see that the volumes in the media controls are turned up and nothing is muted.
If the above does not work:
Try another set of speakers. If the new speakers do not work, try another sound card.
Jerry G.
The volume on my philips flat screen wont work
I don't know the particulars for your model of set but you can try looking in to the user menus and see if there is a setting for fixed or varible volume level.
If you have no sound, check for the mute mode. Also check that the set is not in SAP.
Jerry G.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
