I have echo p403. Similar but not exactly my issue. Rebuild the carb if you didn't already. Alternatively, you can buy a new carb approx 35$. After parts purchase and your time, 35$ isn't to expensive. The carb uses a diaphragm that seems to melts over time and use. I'm not a chemist, I can only tell you what I found inside, the diaphragm was like jelly after 10+ years of use.
SOURCE: Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
SOURCE: Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
