Question about Microsoft Xbox Console
Original Xbox When I turn on my xbox, it does the normal start up and then goes right to the clock screen and locks up. Has worked fine up until now.
  • Anonymous Oct 08, 2008
    xbox starts up and goes to the clock set up screen
    after that no controller response at all
Error 21
Posted on Oct 12, 2008
Try unplugging the xbox then hit the power button and leave it unplugged all night and then try it. If that don't help then your hard drive may be going bad or your dashboard files are screwed up. You can email me at c_a_messmer@hotmail.com if you have any questions.
Posted on Aug 29, 2008
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
My XBox 360 does not show up on the tv screen, but it has sound.
this happens a lot. what happend is the red white and yellow wires that you put in the back of your tv. the red one is not in the right area or
there is a switch right were you plug in that cable with the red whit and yellow cables to your xbox that says hd or normal switch that to whatever your tv is
Jul 17, 2009 | Microsoft Xbox 360 Console
Red light on first xbox
Cracked solder points try turning it on with the fan unpluged and wait untill you get the 2 red rings lights 1 and 3 then wait until the xbox shuts off then wait a couple of min. then reconnect the fan and turn it on to see what happends.
May 23, 2009 | Microsoft Xbox 360 Console
I have fable for the original xbox and it been working fine intill i took it to my friends house and played it on his xbox, then when i came home and trying to play it on my own xbox it plays the start up...
Both Fable one and two have glithches that pretty much screw up the game for good. I had a problem when i got fable one and it kept saying it had a problem ever time i tried to start it up. You can get a used copy for like ten dollars though.
Dec 06, 2008 | SG Xbox Fable (XBFAP)
Original xbox
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
If you get an error 13 after this, please read up on the error 13 explanation!
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
The error it gives is because of the incompatibility between the (older) dashboard (4920) that older slayer cd installs and the new dashboard/kernel versions found in some new xbox's and found in xbox's that have been connected to xbox live (when you go on xbox-live, it'll upgrade your dashboard file to i believe it is now 5659.03. This dasboard is incompatible with the dash that (old) slayer cd installs (for example 2.5 or lower) for you.
(In detail, in the eeprom chip there is a kernel which is incompatible with the dashboard (4920) that slayer installs.)
So what do you do to fix it? You can use the dashupdate found on most new xbox games! Be sure to 1st unplug your ethernet cable before you do so!!!
Besides that, just use a good installation disc and all is fine. Use a 2.6 slayer or something similar
Dec 26, 2007 | Microsoft Xbox Console
Xbox error code 16
-Install your hdd
-lock hdd
Nov 27, 2007 | Microsoft Xbox Console
Xbox console
have you tried setting Auto sign-in to off? It's in main menu->settings->auto sign-in
Nov 20, 2007 | Microsoft Xbox Console
Xbox
-Install your hdd
-lock hdd
Oct 23, 2007 | Microsoft Xbox Console
XBOX - Flashing Red Ring on console after startup,
I had the same problem & it turned out the plugs wernt all the way in so check & make sure thaey are in
Aug 01, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
80 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
