Question about Toshiba e350 Pocket PC
How to connect to internet
Could someone tell me how to connect my e350 to internet. I have aol broadband but never attempted connecting my Pocket PC. What do I need to buy extra and how to connect?
    Master:
  • 903 Answers
You have two possibilities to connect your PDA to internet. First one is to use connection of your PC or Notebook. Check please connection settings under Start>Settings>Connections. If you want to make automatically connection to Internet, use first option. Under “Modify” you have possibility to create new connection. Did you already try to make connection like this? Look on http://www.microsoft.com/windowsmobile/help/pocketpc/ossupport.aspx There you can find lots of useful information how to connect PDA to Internet. If you want to make connection using Bluetooth, look at https://eu.computers.toshiba-europe.com . There you can find Bluetooth SD Card 2 which you need for Bluetooth connection.
Posted on Sep 11, 2005
SOURCE:
Can you tell me what the basic settings are for AOL connection in the UK? PPPO-A o PPPO-E? LLC or VC? etc.
It all depends upon your router and broadband / internet connection, as it is all based upon what connection to the net you have
PPOA is adsl
PPOE is over ethernet for Cable type connections
May 11, 2011 | Office Equipment & Supplies
I have this pocket pc and i wnat to know if i can
Unfortunately, I think you are out of luck here. As far as I know, the e350 is not Wi-Fi enabled. Besides, its SDIO interface seems to be kinda proprietary, i.e.it is a subset of the SDIO standards. I don't know any Wi-Fi SD cards which would work with it. If Wi-Fi connection is a must for you, I'm afraid you will have to switch to a new phone, which either has built in Wi-Fi, or, at least, has a fully featured SDIO interface.
Hope you are able to sort your problems out.
Regards, Carlos
Apr 25, 2010 | Toshiba e350 Pocket PC
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
Wont connect to internet
Well in case it always try you to connect through dial-up.
Check the option (connect to and change in broadband, in case you using a aol software to connect to internet
Hope this will resolve your issue.
Sep 25, 2009 | D-Link DU-562M Modem
Toshiba e350 Pocket PC Charger lost
Does it charge if you connect it to a pc with a USbcable
Mar 22, 2009 | Computers & Internet
Can't locate a Modem connection
Ok, First off, Yes, if you have a plug in the back of your computer that allows a standard phone connection wire from computer to the wall, that usually means you have a modem. If you have the ability to get Broadband internet, my suggestion is to get that instead. Its more reliable and doesnt have an automatic disconnect feature that AOL has always had. Also, if you already have broadband, then you can connect with AOL directly through the broadband connection and skip the Modem use entirely. Best i can tell you, other than if your computer is not finding the modem, that means its been either disabled or is missing the drivers.
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
After aol main computer went down they told me to reoncifugre the router i dont know how to do this and as i dont have a home fone line i cnt ring them any help please?
First thing to do is try to connect to the Internet without AOL then sign on to AOL using the broadband connection. When Internet Explorer is open, even without a connection, go to Tools>Internet Options>Connections and check the 'Never Dial a Connection', Click on Advanced and check the 'Automatically Detect Settings' check box. If you are not connecting to the Internet then turn off or unplug the power to the modem, turn it back on and wait 2 minutes. If you don't connect then do the same with the router power. If you still haven't connected using just Internet Explorer, NOT AOL, then talk to your router directly:) Do this by Start>Run>type http://192.168.1.1 (Linksys) or http://192.168.10.1 (Motorola). A logon screen appears. User Name is the manufacturer's name and 'admin' is the password. A web page or dashboard will appear. For a cable modem select DHCP. For DSL select PPPoE. Static addresses can also be entered if you know what they are but probably not. When you see ip addresses listed open Internet Explorer, Firefox, Opera, Chrome or whatever browser flavor you like EXCEPT AOL. Once connected to the Internet then go to AOL. More specifics on your broadband service and hardware makes will get you more specific help if you need. Happy surfing!
Oct 15, 2008 | Computers & Internet
AOL broadband connection
The answer is very simple ... Uninstall the AOL browser, you do not need it to connect to the internet, AOL's browser, as I have discovered chokes your bandwidth and slows down your PC. I would strongly recommend using something like Firefox (you can add the AOL toolbar if needed). I removed AOL's browser over a year ago and have not had a single problem, bespite the fact that AOL insist I must have it installed on my PC ... Absolute rubbish.
Aug 17, 2008 | Dell Dimension 3000 PC Desktop
I dont no how to conect my asus eee pc 2gb to my broadband so i cant use my pc
AOL does not support Linux, so you cannot install their software. Did you tell them you had a Linux PC?
To help further you must explain what your 'network' is.
Do you have a wireless network or do you use ethernet cable?
You should be able to have internet access without needing AOL software.
Please give details of your network and equipment.
Thanks
S
Aug 08, 2008 | ASUS Eee 4G Notebook
Wi-Fi on an e350
I am not sure but I think that e350 do not support Wi-Fi connection. As far as I know it works with Bluetooth SD card.
Sep 11, 2005 | Toshiba e350 Pocket PC
Toshiba e350 Pocket PC Logo
1,003 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
