Question about RCA DRC6355N DVD Player/VCR
Rca dvd player / video cassette recorder DRC6355n PSCAN SPLIT SCREEN
I get a Split Screen on my tv and a message in bright yelow letters reading PSCAN! I am desperate! Help Please! how do I get rid of it?
  • Anonymous Dec 10, 2008
    split screen and PSCAN alert. help
  • Anonymous Mar 27, 2009
    split screen with pscan square
5 Suggested Answers
SOURCE: memorex dvd player pscan split screen
I just had the same problem and I looked in the back of my Memorex dvd player and there was actually a button where you can turn the progressive scan on or off.
Posted on Jan 05, 2007
SOURCE: Pscan - split screen
There is a switch on the back that will fix this.
Posted on Mar 24, 2008
SOURCE: Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Posted on Jun 03, 2008
  • 217 Answers
SOURCE: After viewing a dvd and
it should be a setting somewhere in your dvd systems settings
Posted on Jul 11, 2008
SOURCE: PSCAN MESSAGE
pscan showed up on my dvd player and I shut the switch off on the back...all good! thanks for the inpu!
Posted on Aug 29, 2008
Pscan message and split screen
well on your memorix dvd player you will get a orange triangle that says pscan (progressive scan) you will go to the back of you dvd/vcr and on the right hand side you will see a switch to turn on and off the pscan you will switch it off and you will be set to go
Aug 23, 2009 | Memorex MVD2022 DVD Player
How to get the pscan and split screen go off
press video mode or pscan button on remote
Jul 11, 2009 | Televison & Video
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
I work for Memorex technical support. Our customer service phone number is 1-800-919-3647.
On the back of your player you should see a switch that can slide back and forth that's marked PSCAN. Slide the switch into the opposite position from which it's in now. The should solve your problem.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 05, 2009 | Coby DVD-224 DVD Player
I have a split screen and it says pscan when we use our go video
Sounds like the cable has went bad. I had the same problem with dvd to TV, replaced the cables & it was fixed. Hope this helps.
Dec 27, 2008 | GoVideo Go Video Progressive Scan DVD...
The screen is split ! PSCAN
Take a look at the back of the dvd player there should be a switch that says Progressive scan on/off. Switch it to off. Problem solved !!!
Nov 30, 2008 | Memorex MVD2042 DVD Player
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
PSCAN MESSAGE
Mar 08, 2008 | Memorex MVD2042 DVD Player
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Mar 06, 2008 | RCA DRC200N
RCA DRC6355N DVD Player/VCR Logo
267 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
