Hi!
I have a problem with my manual transmission. I have a hard time to shift my gear from neutral to 1st. Then, 2nd gear back to 1st. Its like there is something blicking my transmission. Need help.
If you cannot change the gears when the engine is not running, then you probably have an internal transmission problem. Could be input shaft or cluster gear assembly
Ever notice that while driving that the car hesitates or refuses to go into gear? ... For automatic transmissions, you might notice that when shifting into drive or park ....Neutral and park gears no problem, but drive, 1st, 2nd and reverse engages ...
Jun 5, 2015 - When I put it in drive, and begin to drive away the transmission will put itself in neutral. When I slow back down, it will go back into gear.
? 3:59 https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
hi i have a 2004/05 misubishi lancer just recently the neutral light keeps blinking ... (2nd to 1 st gear ).i replaced atf and filter it does the same thing since ? bought ?t 3 ... having is driving with the overdrive on it won't shift when shift into 3rd gear it just ... I have a ls400 and my auto transmission shift hard when I ...
Aug 25, 2005 - 28 posts - ‎18 authors
My co-workers tell me I am just not shifting into 2nd gear properly, but I am making an effort to make ... When it won't engage in 2nd can you kick it up to 3rd OK & do the other gears engage OK? ... 25th August 2005, 13:05.
Transmission won't shift out of 2nd gear - Honda TRX Forums: Honda ...www.trx450r.org > ... > 450R Performance and Mods. > EngineDec 24, 2012 - Just rebuilt my 05, new crank and piston (it did not blow up). I didn't touch the gears or shift forks except to make sure they spun and were not.Won't shift out of 2nd. [Archive] - Chevy TrailBlazer, TrailBla
TPS SENSOR. IT CONTROLS SHIFTING AT THE RIGHT TIME AND COULD ALSO CAUSE ALL OF THE SYNMTHOMS THAT YOU HAVE LISTED SOMETIMES WITH OUT GIVING YOU A CODE GOOD LUCK
That transmission is one that has been used for years in Dodge and Plymouth vans. Do you know when the last time was that the fluid was flushed out and replaced? It's pretty important that it be done every 90K miles.......have it checked out.
When was the last time the transmission fluid and filter changed? I would have that serviced first. If it is an electronic transmission, the line pressure might also have to be reset.
What you need to check is the transmission release bearing because if there is a clearance on the release bearing you will encounter this problem and also check the transmission oil.
