1998 Volkswagen Jetta Logo
Posted on Aug 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A/c issue I just bought a 1998 Jetta TDI. The previous oner said a/c needed charging. I checked the system with a guage and it reads high pressure( on low pressure side). Fans work well, when you push a/c button sounds like compressor is working, but no cold/cool air. What now?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12005
Points
I just replaced the Volkswagen/Audi Auxiliary Fan for $26.86 (Control Unit # 1J0 919 506 K)... FIXED THE PROBLEM!!!
Originally I had: Both fans and compressor not working, all fuses good, and all grounds good, and an extremely high 134a pressure on both the High and Low side. I bought the part on eBay, swapped it out, and instantly problem solved!
(Side note) I discovered that one fan is not working correctly (which I will address later), however the A/C is working GREAT again!
Anonymous
Level 3:
  • Master 1,586 Answers
  • Posted on Aug 29, 2008
Anonymous
Master
Level 3:
Answers
1586
Questions
0
Helped
821308
Points
5018
Could be a couple things - one, if the fan switch for the AC condenser is not working, it'll keep the AC from kicking on, but that's usually seen by the compressor not coming on. When you activate the AC, do your RPM drop down at all? It should. If it does, the compressor is kicking on and you probably have a problem with the expansion valve, which is what flash chills the air. The car is pumping freon around but it's not cooling enough to cool the car. That's likely an expansion valve problem.
If you turn it on and the revs don't dip down momentarily, the compressor isn't coming on, and it could be the fan switch underhood or the AC relay.
My 2006 vw jetta tdi lost power and died wont restart am told need code to restart but dont have right code
You will have to have the fault codes read by a code reading machine . That will tell you why the engine stopped. I am suggesting that you check to see if the cam shaft is turning when you try to start it as the timing belt may be broken. Repair/replace items listed by the codes -reset the CPU with the code reader
Vw
The battery warning light means the alternator is not charging the battery. And the check engine light is probably for the same issue.
Have you had the charging system checked ?
2answers
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
2001 Jetta TDI - Sluggish with black smoke
not usually you would hear a vacuum leak
Recharge air on a 1998 oldsmobile bravada
You didnt actually post a question so I will try to help. You need 134a refrigerant and a way to get it into the system. Places like walmart and Advance Auto Parts has what you need. Most diy kits have a hose to connect to the Low Pressure side of the ac system and a guage. The other end of the guage has a connector that fits on the can of 134a. Start the car, turn the ac on high, open the hood. Being careful of moving parts under the hood, connect the hose to the Low Pressure side of the ac and see where the guage is reading. Most are color coded. If it says it needs charged, squeeze the trigger until the can is empty and take another reading. Continue until the guage is in normal range.
2answers
Jetta 2003 temperature gauge not working...
Replace it First as Overheating Can Damage it and cause Fauls reading or NO reading
1helpful
Low oil pressure reading on ´96 Toyota T100
hi ben
my answer would be yes i would wory about it...
Guages are put on vehicals for a reason not just for looks i would have the car hooked to a diagnostic center and checked even though the guage may be faulty but i wouldnt take a chance
Jetta 2003 TDI
My mechanic in our town did a quick computer check. Car computer indicated a low level of antifreeze, he topped it up, cleared all messages off the car computer and said to watch the the heat guage for any further irregularities. I'll keep an eye on it, love the car, great mileage fun to drive.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
