Question about Kenmore 22422 Top Load Washer
Kenmore 80 Series Model 22832100
Washer will wash but will not Rinse or Spin !
  • corrala Aug 30, 2008
    My washing machine does all the cycle but in the moment it needs to draing the water stop. Then, I set it to rinse and start it. When it needs to draind it stop again. In another word the wahing machine does not all the cycles. I did try the steps for the lid switch. The switch is not broken and I did the 2 mounting scews. I still have the same problem.
  • 5,911 Answers
It sounds like you have a lid switch malfunction. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number as "110.22832100" and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949238). The lid strike is listed as item 20 (part #350733). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. This total repair will cost you a little more than $40. Let me know if you suspect you have other problems. Sometimes the timer can cause certain segments of the wash cycle not to work as well, but this generally is a bit more expensive, and not as common. The lid switch is a more common problem, because of the repeated use it gets while opening and closing the lid. The switch just simply wears out. I hope this helps you.
Posted on Aug 30, 2008
Kenmore 80 series model 22832100 does not always spin fast enougf
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Kenmore Washing Machines
No rinse, no spin kenmore series 80
need to see if your timer is not advancing to next cycle. if not then replace timer
Jun 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
281 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
