Question about Mitsubishi WS-65809 65" Rear Projection Television
When there?s any bright white light, the unit just loses the signal .
The TV is a 65 inch Mitsibishi TV (tube / rear projection). Everything else works fine without a hitch (Tivo, Cable, Wii, PS3). It is only the xBox360 When there’s any bright white light, the unit just loses the signal for some reason and nothing is displayed, there’s not even any sound. When the white light dies down, then the signal returns. Needles to say, this makes watching videos through the Xbox 360 virtually impossible, as well as playing several video games.
  • 927 Answers
Good Day, littlejhon4u;
Try this and/or try using different input: White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change. Good Luck, big IRISH. PS; Adjust this ONLY.
Posted on Aug 31, 2008
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
Dec 08, 2010 | Mitsubishi WD-65731 65" HDTV
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
My 65 inch Mitsibishi rear projection lost the red when viewing Cable, but the red works when viewing dvd's or playing games. Is it the red color tube or somthing less sinister?
Okay - lets' verify a couple of things -
1) how do you have cable connected - through -
A) Cable box or
B) no Cable box and the RF Coaxial Cable directly connected into the Rear Projection RF input connector.
\What I believe is that you have possibly a Component cable 'Red - Green - Blue' that is hooked up between your cable box and your TV.
Now the issue is that the Red connection isn't pushed in all the way on either the TV or the Cable box.
Let me know.
Blessings,
A/V Media Guy
Nov 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No power to a 65" Projection Mitsibishi.
The inputs may have to be re-soldered this is a common issue with projection screens
Oct 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba Projection Picture discoloration
burn in on one of the tubes try magic focus?
Mar 12, 2007 | Toshiba 65HDX82 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
