Question about Nokia 6030 Cellular Phone
When switched on getting display as "LOCAL MODE" its not working completly.
  • bigbossyaa Aug 29, 2008
    hai
    No its neither droped or shorted from charging. i just switched off as there was no signal . when i tried 2 switch on its givig disply as LOCAL MODE.M a technecal person lz help me
  • 29 Answers
The phone need to be repair hardware..
it's either you drop your phone or shorted from charging..
Posted on Aug 29, 2008
How to remove demo mode
  1. Press Esc + zlngdeu0pahwwfbyzfavlg78duz9utzlux5vgun0flmbpwc7e-avz2fbwiptetjfkkssz1ja=w24 + Power. The screen displays a yellow exclamation point (!).
  2. Press Ctrl + D to begin dev mode, then Enter. The screen displays a red exclamation point.
  3. Press Ctrl + D. The Chromebook deletes its local data, returning to its initial state. The deletion takes approximately 15 minutes.
  4. When the transaction completes, press the spacebar, then press Enter to return to verified mode.
This comes from Googles support page
Wipe device data
Aug 13, 2014 | HP Pavilion Chromebook 14
Samung chromebook xe303c12 turns on to white screen chrome screen then turns black with power light on
Here is a trick you can use: You can put the Chromebook into Developer Mode, then once it is in Developer Mode you can switch it back into normal mode and it should totally wipe the Chromebook without requiring any USB flash drive or any SD flash card etc.
But remember that just like a Powerwash or a USB ChromeOS restore, this process will wipe all local files you have stored on your Chromebook's SSD.
best of luck ! And be certain to return to let us know if this helped.
-JW
PS: Remember that when using a Chromebook you should never store important files locally on the SSD HardDiskDrive shelf; Instead, store them in your Google Drive or if you must store them locally use something like flash storage media. A Powerwash or a switching into Developer Mode will wipe all SSD local files.
https://support.google.com/chrome/a/answer/1360642?hl=en for Samsung Chromebook XE303C12-A01
  1. Press ESC + Samsung Chromebook Refresh key + POWER. The screen displays a yellow exclamation point (!).
  2. Press CTRL + D to begin dev mode, then ENTER. The screen displays a red exclamation point.
  3. Press CTRL + D, then ENTER. The Chromebook deletes its local data, returning to its initial state. The deletion takes approximately 15 minutes.
  4. When the transaction completes, press the spacebar, then press ENTER to return to verified mode.
Jan 21, 2014 | Samsung Chromebook Series 3 XE303C12
How do I reset the computers timing belt information in a Toyota 2007 4.7L (VIN T, 5th digit, 2UZFE eng, 8 cyl) after making a timing belt change?
1. T-BELT MODE DISPLAY
a) With ignition turned ON, using the trip switch (select/reset button) change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display "15" (0,000km) is displayed (ie. 150,000km).
2. REWRITING REPLACEMENT VALUES
While in the T-Belt mode, each press of the trip switch will change the displayed value by 10,000km increments. Once " 20 " (200,000km) is reached the display reverts back to " 1 " (10,000km) again. Remember, this setting is the number of kilometres to be travelled before the light comes on next, and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is 150,000km, but this should be checked against each different markets servicing recommendation. This being the case, you shouldn't need to change from the default setting of "15".
Obviously for the US, the ODO is in miles, and I guess the T-Belt warning would be set in 10,000 mile intervals.
3. T-BELT WARNING RESET COMPLETION
a) After setting the replacement setting value, hold the trip switch ON for more than 5 seconds then release the switch.
b) Check that the display has now changed back to ODO and that the warning light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has not been performed, the T-Belt warning IS reset.
Oct 30, 2010 | Toyota Tundra Cars & Trucks
Reset drum life on oki c5500n
try this:
1) Power on printer while holding both the + & - buttons simultaneously; release when "Okiuser" is displayed.
2) Press + or - until "Engine Diag" Mode is displayed; press Enter and Diagnostic Mode xx.xx.xx will be displayed
3) Press and hold both Enter & On-line simultaneously until Eng Diag Level3 is displayed
4) Press + or - until Local Parameter Set is displayed; release and press Enter
5) Press + or - until it displays Factory Mode; if it displays Factory Mode Twice with an asterisk next to one then it is in Factory Mode; Press Enter, Press + or - until it displays Factory Mode & Shipping Mode on the display; then press and hold On-line & Cancel simultaneously; when it stops blinking an asterisk should be displayed next to Shipping Mode, which becomes the default mode.
6) Power printer off then on to complete the procedure.
Oct 12, 2009 | OKI C5500n Printer
Format error on my nw-505
be sure to format using the MENU mode on the unit and ADVANCE MENU then FORMAT Press and hold the search/menu button for half a second in stop mode. The menu screen is displayed. Rotate the shuttle switch to select "Advanced Menu" > and press the play/stop button to confirm. Rotate the shuttle switch to select "Format" and press the play/stop button to confirm. Rotate the shuttle switch to select "OK" and press the play/stop button to confirm. "Formatting..." blinks and start formatting. When formatting is complete "complete" is displayed.
This is how i get rid of the problem "Format Error".
May 11, 2009 | Audio Players & Recorders
Nokia 1600 displaying local mode
didn't you try another battery?
Oct 16, 2008 | Nokia 6120
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
just remove the battery and short the battery polls (+, - ).
Dec 03, 2007 | Nokia 1600 Cellular Phone
Sony NW-E505 MP3 Format Error
Gogata
Oct 11, 2007 | Sony NW-E505 MP3 Player
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Aug 23, 2007 | Toshiba e-Studio 350 Copier
Nokia 6030 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
