Question about Linksys Wireless-N WRT150N Router
Router Question I have an iMac running OSX 10.5 and am trying to set up a Linksys WRT150N router by way of a Comcast modem. I have been unable to access the linksys web base setup page as the router seems to receive the internet connection but the wireless light on the router does not light up and internet service does not go beyond it. I have tried resetting the router several times, shut it all down and re started the modem then router while all connected to the iMac. Still nothing. The Mac gets noting through the ethernet connection nor wirelessly. Any suggestions are welcome.
  • crimsonphoen Aug 29, 2008
    Thank you. Best advice I have had and confirms a feeling I had about the router.
    Novelist:
  • 144 Answers
Hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Posted on Aug 29, 2008
  • Linksys Master
  • 6,487 Answers
If the wireless light of the router is OFF and you already reset the router , Reset meaning you press and hold the reset button of the router for 10 seconds and still the wireless light is OFF this can only mean one thing the router is already bad. If you want you can call Linksys tech support so they can also do some further troubkeshooting but I can say the router is already bad.. This is the number for Linksys 800-3267114..
Hope that helps..........
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
Linksys WRT150N is connected to the internet via cable modem, but the wireless router shows no internet connection and I am unable to log into teh router manually?
Reset the router for 30 seconds. Then power cycle the router and modem.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 01, 2010 | Linksys Wireless-N WRT150N Router
CONFIGURATION PROBLEM ON MY LINKSYS WRT150N ROUTER
Are you trying to set up the router.
You can do it manually without the CD.
Mar 05, 2010 | Linksys Wireless-N WRT150N Router
Linksys WRT150N router disappearing from PC
If you aren't able to access the router even using the hard wired connection, there seems to be a problem. Resetting won't work. You must hard reset the router. And here are the steps.
1. Push the reset button and hold it for a minute
2. While you are holding the reset button pull out the power cable every 10 second and put it back in right away. So in a minute you would be doing it 4-5 times
Try this a couple of times and if this still doesn't work, its time for getting your router replaced from linksys.
regards
Sandeep
Oct 13, 2009 | Linksys Wireless-N WRT150N Router
I am having trouble setting up my WRT150N
Try to place the modem in bridged mode
Then run the setup wizard
It should work
Else configure the details Manually on the router
Sep 26, 2009 | Linksys Wireless-N WRT150N Router
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Wireless network using usb modem
First thing that you have to do is to check if the wireless light on your linksys wrt150N is lit. If it is, then that means that it is emitting wireless signal so you can connect wirelessly.
Then, install your verizon usb mobile broadband card on your desktop. When you plug it to the usb port, a pop up balloon would show on your page which would say FOUND NEW HARDWARE. you could click on it and choose the CD-drive to install OR you can run the cd and have it install on itself.
After installing the usb, try to connect to your wireless network. Start > Connect to > and then click on the name of your wireless network.
Apr 08, 2009 | Linksys Wireless-N WRT150N Router
Wrt54gs router for iMAC
go to page 7
Follow the step by step for using the web based interface.
Hope this helps.
Nov 30, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-N WRT150N Router Logo
153 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
